StryfeS13's Build Thread..No more KA-T...5.3L LSx
Razi
Car: Moo
I didn't know EFI Specialist could do that!
Darn, I shoulda asked for an atmo bov tune...
Oh yeah, I learned a few months ago that the sandwich adapter ports are actually getting unfiltered oil, as the oil gets filtered and gets passed through the center of the filter.
So I think the aftermarket oil pressure sensor should go on the sandwich adapter since it won't matter, and your oil feed like gets teed with the stock oil pressure sensor, since that gets the filtered oil.
StryfeS13
Car: 1993 Nissan 240SX
So this is how I'm going to do my PCV/Valve cover breather set up.
Yes, I know the PCV is already a check valve, but once it sees more than 5 psi, air starts seeping past. This is bad!!!
So I searched forever, and decided the best way is like this. (This is assuming you have an emissions/PCV deleted manifold like me)
Out of boost: PCV -> Check Valve -> Intake Manifold
In boost: VC Breather -> Pre-Turbo intake
Tools you will need:
Check Valve (McMaster-Carr part ##7775k53)
3/8 X 3/8 Barb X MIP fittings for check valve (Home depot)
11/36 Drill bit
1/8" NPT to 3/8" hose fitting (Pep Boys, etc)
1/8" NPT Tap (NAPA)
Check Valve:
Tap & 1/8" X 3/8" fitting:
First, I decided I wanted my fitting right on the side of the intake manifold, near the brake booster line. This is for ease of access, and I thought it was a good spot. (Marked by black sharpie dot)
Drill your hole with the 11/36" bit, and then tap it with the 1/8" NPT tap:
And then finally, you just screw your fitting in:
StryfeS13
Got my oil pressure gauge today...
Gauge and stuff
Installed
StryfeS13
This s*** isn't gonna leak. Drilled/tapped, plug inserted with jbweld on the threads, jbweld coated over the top of the plug so no air can escape. Ghetto, but solid. :chuckle:
mastakilla08
Car: 1992 hatch, 1989 piggy coupe, 1991 coupe silv.
Love your build man you got alot goin on!! best of luck to you I have a t3 CAT turbo for sale if interested ha jk man
Razi
Car: Moo
Haha JBweld ftw.
A stud on my head was not coming off so I JBwelded a nut onto there and came back and undid it an hour later, threaded the stud right out!
StryfeS13
Well, I was gonna boost it this weekend, install everythin etc.
But that's not going to be happening. Motor was running funny and cylinder 4 reads 50 PSI. The piston is not damaged and the rings are not bad. So it must be a valve.
Disassemble starts tomorrow.
costa_rican13
Car: 1993 s13 coupe
damn, damn, damn.... always something eff up the big plan.
costa_rican13
Car: 1993 s13 coupe
7x13
Car: '89 240SX Hatch (Sold)
Sweet Build.
You made me want a Turbo KA even more now
S13AL
Car: 1991 240sx hatch with blacktop s13 sr20det, HKS Hipermax III suspension, HKS Sport exhaust, Blitz downpipe, S15 Sylvia HLSD, 300zx/J30 5 lug and brakes, and mesh wheels
I like the work you did with the new PCV. I've never really thought about adding new vacuum ports.
StryfeS13
So I went through the motor, pulled the head off etc. And luckily there is no piston damage at all. I can see a valve is bent (light shows through at a certain angle), so I'll be replacing that. Then finally I can boost this thing. Freaking problems!
Razi
Car: Moo
It's all the small things that get in your way.
I hope it runs problem free after the valve is replaced man!
StryfeS13
Here's how the motor looks now :frown:
Cylinders still have a nice crosshatch...
Head is still clean...
Look...daylight! s*** valve
Razi
Car: Moo
Darn engines. :P
StryfeS13
I figured since my motor is taken apart I can clean up some stuff, and make it look cleaner.
Sandblasted and painted the valve cover (picture came out weird):
Sandblasted the upper front cover
dgms240
Car: '90 s13 hatch ka24det
lookin good man keep it up! hey this kinda goes without saying, but make sure you clean out the valve cover really well if you sand blasted it. stuff can get stuck under the baffle like underside of the cover.
StryfeS13
Yeah I know.
I've had the head back on the car for 2 days now, but have been sick so I can't get the intake manifold on haha.
Should be boosted soon if all goes well.
StryfeS13
Well...the KA lives again.
Razi
Car: Moo
Yay!
dgms240
Nice!
420sxWETDREAMS
Car: 1991 240sx Hatchback
Love the angry face with tape lmao! The valve cover came out great also.
StryfeS13
So....
it's boosted
StryfeS13
Razi
Car: Moo
:o
Oh snap!
Does it run?
StryfeS13
Yeah it runs.
I have some kinks to work out of course, but it actually goes into boost this time.
I've only had it at half throttle and it pulls about as hard as my car used to at full throttle.
Razi
Car: Moo
Good news!
StryfeS13
Here's another pic, with my Cxracing HKS edition intercooler LOL
Razi
Car: Moo
Poser! :P
StryfeS13
Hahaha. I couldn't stand it just being plain.
Hey, atleast it's not an interfooler. hahaha
