180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Jun 14, 2004 10:08 pm
Found a strong possibility. When I was rummaging through my garage, found a vac/pressure gauge. Hooked it up to my vac port that was free from the carbon canister removal. Connected the hose, and fired it up. Strange 0 psi at the throttle plate. So I shut down the car and double check my vac lines. Everything looked good, but one thing I didn't check more thoroughly was the intercooler itself. Checked all the hoses and what not connecting to it, but not the actual face of the intercooler. Saw some damage but everything looked good at a glance. Once it was removed, had a closer look at all the damage and bam. Found a cut. Double checked by pouring water into the intercooler and saw it was pissing like a little boy.
Now I've got a few choices, take it to a welder and pay some extraordinary sum to have it fixed, or get a new one, or find some other means of patching it up for a month or so until I can save enough for another new side mount like ARC or buy a new FMIC. I think I'll do the patch and new FMIC though. I thought about using JB Weld, but figured since it's for patching steel, it's probably not a good idea to use on aluminum. Might get a radiator patch kit since I'm only using stock boost for now and need a quick fix to get the bugger out of my buddy's garage. Any other ideas for the fix on the SMIC?
Already replaced the plugs, o2 sensor on the bastard, and gonna check the timing first thing the smic's fixed. Once everything's clear and good to go, bam, start practicing driving manuals. hee hee hee.
