180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Jun 14, 2004 10:08 pm
My #1 guess now is that my IACV's gone bye bye and along the way left me a message saying "adios sucker".
Update:Got the car to idle pretty well when hot. It stumbled a little bit still when it was hot but no where near death. Double checked the wiring with no faults at the ecu area where I originally thought there might be a possibility of fault. No luck.
Parts so far replaced:MAFS, coolant temp sensor, FPR
Parts checked:-- tested the injectors both with a screwdriver to listen to the little clicking inside the injector and swapped them over with a friend. Not the injectors.-- shook around the plug on the MAFS, tried it in different positions, this part is good and so is the wiring for it.-- had a doubt I got the right part at Kragens for the water temp sensor, well it works and fit the harness. Can't be that either.-- compression tested the bugger, all cylinders within spec.-- pressurized the entire intake system from the back of the hotpipe all the way to the throttle. Pressure held.-- timing is right at 15 BTDC when the car was warm, and the TPS off. I was checking the timing light though when the car was on the warm up phase, and the timing was switching from 20 and 10 btdc which is strange to me. Is that normal?
** while car was running, had different vac hoses closed off to see if that changed the idle at all...no luck. Although this one stands out a bit to me because when I pulled some of the vac lines during the fast idle phase, I couldn't tell if there was an rpm fluctuation because I was already getting that.
In conclusion:I think I'm gonna get shafted hard. Like San Quentin Prison hard. Checking out phase2, they want like $300 for that part...plus tax...plus shipping...yeah I think I'm quite right to think San Quentin hard eh? But before I decide to take a ride on the bone rollercoaster, what are your thoughts on this Nistech, Chris?
