Alrighty, with the PCV seperate from the vac system, I started up the motor and it still idled like crap. It gets better alot faster than before though. So I popped the IACV hose off and plugged up the hose with my thumb. The motor died instantly. I guess I don't have a vac leak...but I still have the poo for idle.
Checked the resistances across my coilpacks and they all read 0.7 - 0.8 ohms...but is this the right way to test them?
Only other thing I could think of that could be causing my issue was my ecu since I don't have a vac leak before or after the throttle, I've replaced my coolant temp sensor, checked over and switched my mafs, cleaned and replaced my IACV, only other thing that I can possibly think of is my ecu. Could that be the culprit? I'm gonna put my ecu in my buddy's car tomorrow to see if it is the ecu. If not then I guess I need to double check the harness again as that'd be the only other thing that could be wrong.
Any other ideas before I take the plunge and possibly tear apart my harness again?
Oh here's a movie clip (1.29Mb) of the idle.
http://youngpark.home.mindspring.com/idle.MPG
