180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Jun 14, 2004 10:08 pm
Oh those vac lines were pulled for a clear picture of the throttle's setup. The top passenger side vac is normally occupied by the FPR's vac line, and the other by the bov's vac line. There's also the large throttle hose that runs from the cold pipe to the throttle, and then the smaller hose that runs from the cold pipe to the iacv hose.
Nistech, can do with the pictures of the intake manifold. I'll get on that this afternoon. I'm not going to be able to swap out the ecm till later tonight since that's when my buddy's coming around with his sr.
Chris, yeah vac leaks suck. So far I've checked the compression, timing, ignition, fuel, etc, etc. As far as I know, there isn't a vac leak anymore before or after the throttle. I've already popped the iacv hose when it was running, capped it with my thumb and the motor died instantly. Before I redid the intake manifold, the motor would keep going when I capped the IACV's hose and would have the vac drop slowly till it died. If I were to screw down the IACV's adjuster all the way down would it kill the motor too? I think I'll give this a try since I've not too many other things left I can think of.
I think I will double check my compression, pop off the intake cam to close up the valves on the intake side and pressurize the intake side again. I'm hoping though that it'll be as simple as a shotty ecm but dunno. Had a buddy who had a shot ecm and it'd idle cold but die hot. Swapped the ecm's and car worked so hopefully it'll be something as simple as that (since I'm lazy lol).
