STILLEN Lightweight Pulleys - Introductory Offer!
All things Altima Coupe.
Beak
Car: 08 Coupe VQ
define large sound systyem... plz
EzeebMOS3
Car: 08 3.5 Altima coupe Black Pre/Tec/CVT 35%/20% tint, Injen intake, Nismo Cat-back, Eibach proline spr
Josh@Stillen wrote:
The Altima's have a spring-loaded belt tensioner, no tightening is required for either pulley. That's a carry-over from the older school systems with a mechanical tightening system.
So does this mean that after the pulley is installed we will have to revisit the garage and have them retighten it?
Also any ideas on the installation price?
Team STILLEN
Car: 2004 G35 Coupe
Beak wrote:define large sound systyem... plz
Robert summed it up very well in another thread, and his expertise in this field will probably be the best advice..
rjdmmfl1 wrote:It appears that Stillen's 2.5 pulley is a lightweight pulley, not a smaller "underdrive" pulley. I only mentioned the 2.5 cars because they have a 115amp alternator. Adding an underdrive pulley, with a high powered system, with a factory alternator "could" be problematic. BUt, since Stillen's 2.5 pulley is just lighter, and not smaller, my guess is they should be 100% fine with that addition! Kyle, please correct me if I'm wrong.
Now, as Kyle stated, the 3.5's will be underdrive pulleys, thus reducing a bit of power to your alternator. HOWEVER, the 3.5's have a 130amp alternator, which should be more than enough for small or even moderate systems! But for someone like myself who's pulling over 2000 watts RMS with my three amplifiers, plus running 8 TV's, an underdrive pulley would not be a good idea!
So guys, my guess would be that you 3.5ers are gonna be just fine with the Stillen underdrive pulley, even if you have an audio sytem (except for guys like applebonker who's pulling ovr 4000 watts RMS!
And you 2.5ers will be just fine with the Stillen pulley, regardless of your audio system! Sorry if I caused any confusion, that was not my intention.
Beak
Car: 08 Coupe VQ
spockrock
Car: Altima Coupe 3.5se
Sith LL_Coupe wrote:Spock, Josh just explained that it is NOT an underdrive pully. It's the same size and diameter of the stock pully, just made of lightweight material, which allows your engine to spin it faster with less energy thus adding to horsepower.
Repeat... no one has to worry about their sound systems with this mod.
Right read my post I was referring to the 3.5 underdrive pulley
Josh@Stillen wrote:Okay, I can see we're going down the path of confusion, let me see if I can set everything straight.. sorry about that.
2.5L pulley is a standard sized pulley - No underdriving of the accessories, no impact on the charging system. Much lighter weight, less weight the engine has to turn, especially when accelerating, where you will benefit from the light weight.
Right I never said the 2.5 pullies are underdriven.
Josh@Stillen wrote:3.5L pulley is an underdrive (smaller) sized pulley - Underdrives the accessories to free additional horsepower. Should not have an impact on charging for MOST users, but for those with large sound systems, consideration should be made.
Right, and thats what I said, only if you have large sound systems, I have not spread any FUD, in fact I think the underdrive pulley is good mod.
Josh@Stillen wrote:spockrock, I can appreciate the desire to quote numbers against these, and I know you've done the research on other boards, but I'd hate to see misinformation spread incorrectly. The pulley discussed on the other boards was an off-brand, no one had really heard of, and is to my knowledge no longer around. Pulley weights, design of the pulley can all have effects on performance and results. To simply use questionable information and postings from those who claim to be engineers isn't really definitive.
We've sold hundreds and hundreds of sets of pulleys over the years, both underdrive and standard, with overwhelming customer happiness.
Look I appreciate everything Stillen has done, but the numbers are math, and apply to any brand. I understand Stillen is a company and if people want magic beans you will sell them magic beans. But you know as well as I know the butt dyno can lie. I am not asking you to stop selling these, I am not asking anyone with a 2.5 don't buy, but to look at the math. The amount of mass involved and radius of the rotational mass are so small and compared to the mass of the car so marginal.
I do have a degree in engineering, I even wear my iron ring proudly, I am confirming what the numbers say. That being said I am not a stubbon man nor am I perfect, I believe stillen has said you wont see anything on the dyno, take a 2.5 do three runs at the track install the pulley and do three more runs at the track, if the pulley makes a difference. I will apologize to Stillen on Nico, and say I was wrong.
As for the 3.5 underdrive pulley, this is a great mod, and anyone wanting to increase performance I think should get it.
Team STILLEN
Car: 2004 G35 Coupe
The first part of it wasn't directed at all to you, you stated the different pulleys and their size correctly, I think some had gotten confused so I wanted to reiterate.
I also wasn't referring to you when I stated "engineers", I meant others in the aforementioned thread.
I just would hate for someone to read some of these posts and take them for absolutes, such as the statement of 2hp in first gear and nothing for other gears. Numbers for dynos have not been established (CVT preventing that for us), so claiming anything is really unfair.
Rotating mass is rotating mass, just like a lightened flywheel. The lighter the object, the less effort necessary.
And yes, we hope that no one is expecting this to feel like a turbo when bolting these up, but they will make a difference, and with every additional performance item added, continue to help improve.
spockrock
Josh@Stillen wrote:Rotating mass is rotating mass, just like a lightened flywheel. The lighter the object, the less effort necessary.
Mass can be the same but reducing the radius also decreases the effort, and you are also forgetting about sprung and unsprung weight.
jungleboogie
Car: '08 VQ35DE Sedan -- Winter Frost w/ Black Leather
i like how these threads remind me of my vector dynamics courses back in college... of course extremely dumbed down yes, but still not a place i wanna revisit.
Jose3.5
Car: 2007 Nissan Altima SE 3.5
Josh, how much would it cost for someone in the Stillen shop to install this?
Strik3r69
Car: 2008 Nissan Altima 2.5s Coupe
Jose3.5 wrote:Josh, how much would it cost for someone in the Stillen shop to install this?
And also josh, i thought the gates belt suppose to be around 15 bucks??
kyle@stillen
Hey Guys,
Josh wanted me to jump in here and address the question regarding cost of installation. Basically you're looking at an hour of labor in our shop and most others.
I'll be back to answer more questions but I'm BURIED right now...
Team STILLEN
Car: 2004 G35 Coupe
Some can be that low, but for whatever reason this belt is a lot more expensive. We were surprised as well.. I haven't seen it, it might be super long, I'll have to pull one out of inventory and get a look at it.
zerodeefex
Car: 2007 Nissan Altima Hybrid Super Black
I know this is a go for sedan guys, but any idea if this fits the 2.5L on the hybrid as well?
Team STILLEN
Car: 2004 G35 Coupe
zerodeefex wrote:I know this is a go for sedan guys, but any idea if this fits the 2.5L on the hybrid as well?
Untested.. but what I can do is call Nissan for the part number of the pulley and compare it to a non-hybrid.. if they match it will absolutely fit. Function will be the same.
zerodeefex
Freaking awesome. I hope they match. It is the same engine, just putting out less power since it has the 40hp electric motor as well.
Team STILLEN
Car: 2004 G35 Coupe
Hmm.. sorry guys, the part numbers are definitely different. Can't say specifically what that might mean, we'll have to get one in here, or if someone can take pictures we might be able to tell absolutely one way or the other.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
I have the 2.5 Stillen Lightweight Pulley on its way to me with one a new belt as well...
I will have one of my friends instal it, but i am going to try to get as much of a "DIY" installation as possible and I will report my experience and feedback on the pulley asap!
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
GO BRIAN GO!!!!
mrodrig2
Car: 2008 Altima Coupe 2.5S CVT
spockrock wrote:I even wear my iron ring proudly
OT post... very jealous, I wish we got those rings in the US. All we get is a job title that's often confused with people who clean up toilets in schools.
zerodeefex
Where would you like me to take the pics? If you can give me a heads up, I can take a peek around with my camera.
Team STILLEN
Car: 2004 G35 Coupe
The crankshaft pulley and pulley configuration...
Team STILLEN
Car: 2004 G35 Coupe
The 3.5L Underdrive Pulleys are now available! Pricing is the same for the introductory period. $149 through 2/15.. Like the 2.5L pulley, we did a limited run to get as many new applications out as possible, first come first serve.
These are a smaller pulley, you'll need a shorter belt, also available from STILLEN.
http://www.stillen.com/product...ltima
RobPaulson
Car: 2013 Subaru WRX
zomgzomgzomg
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
Excellent stillen, you guys rock...
Way to keep making us broke...
Whats next any hints
Ferguson
Car: 09 3.5 SE Coupe
17 370Z Nismo
Order placed.
shmack1388
Car: Altima Coupe 3.5 cvt
just ordered my 3.5 underdrive pully!!. god i cant wait for it to come in
bhs07c
Car: 2007 Nissan Altima 2.5S
Just installed my Lightweight Crank PulleyTheres a bit of difference in the speed it revs and unrevs and the acceleration is definately smoother, however, it wasn't close to the gains I expected but I should have known I wouldn't have seen much of a change when compared to a underdrive pulley. Not worth the cost in my opinion.
mcheddadi
Car: R8
bhs07c wrote:Just installed my Lightweight Crank PulleyTheres a bit of difference in the speed it revs and unrevs and the acceleration is definately smoother, however, it wasn't close to the gains I expected but I should have known I wouldn't have seen much of a change when compared to a underdrive pulley. Not worth the cost in my opinion.
thanks for the honest review!
lilojoj
alright im probably not getting this now. i think i'd rather save up for some eibachs. my car is flying
michaelthepsycho
Car: 09 Maxima S
Well, ever little bit helps :D
