maxentropy wrote:
The 2.5 one is the same size as the OEM pulley which means no change in performance. However one could argue Stillen's is lighter in weight so your car goes faster (less weight + same amount of power = faster). But think about how much lighter this small pulley is... a few ounces? Only other arguement for buying this for the 2.5 is it's "Stillen quality"... last longer? Maybe... maybe not.
I'm no expert but here is my two cents; This is pretty much worthless to a 2.5er. I like Stillen, but if you buy this for a 2.5, either 1) your pulley is bad and you need to replace it or 2) you are very unintelligent.
I have a 3.5 and still can't pull the trigger because of the negatives involved with this. I'll wait till I hear more reviews after another month or two to see how the part is holding up.
Wow, this is full of misinformation. I'm sorry we've done a poor job explaining the benefits, and max I'm not sure why you're so biased against something you haven't tested, but let me try to give some additional information.
The engine has to spin the crank pulley to drive the rest of the accessories. That pulley is heavy and made of steel. We've produced a billet aluminum (a much more expensive process then casting them) version to significantly reduce the weight of the pulley. This improves the ability for the engine to accelerate that pulley, creating faster throttle response, quicker revs, etc.
It's the same principle in lightening the wheel/tires on a car. Less rotating mass means less weight for the driveline to accelerate.
The factory pulley is 4.71lbs, and we reduce it to 1.10lbs. That's a 3.5 pound reduction in weight, or 75% weight savings. Of course you're going to see performance results, but this isn't a turbocharger, your 2.5L is not going to be overtaking 3.5L with the install of a lightweight crank pulley.
Another benefit that can be achieved from pulleys is reducing the size, called underdrive, because they are under-driving the accessories, such as the alternator, water pump, and the A/C when activated. This frees up horsepower, but is also only about a 20% reduction, so there aren't issues with the A/C not keeping up, flickering lights from the alternator, etc. Those problems have existed with other cars and other pulleys, but as that's been shown here (check the reviews), not the way we designed them, so it's not an issue.
So to say someone is unintelligent for purchasing a performance upgrade is just plain wrong, and completely short-sided, and honestly quite surprising.
Just to add: Doing an underdrive setup for the 2.5L isn't possible, because it wouldn't clear part of the engine, the pulley can't physically be smaller in the configuration the 2.5L is in.
