Im talking about the threading between the bolts and the socket. Since the rod will have two threads on both sides, theres the possibility of the rod itself twisting from vibration over timejohnd635 wrote:
I don't think it will be necessary to do that if you attach the little metal clips to the rod. However, I can't get my clips secured! What is the secret for installing them? Do you put them on the cups first then force the cup over the pin? When I try to attach them after the cup is connected to the pin the metal rod won't slide through the hole in the cup. Help please!
The ONLY way for rod down to work when you close the hood is to assemble the upper brackets the way I posted in page 3:eight3six wrote:so i switched mine to rods down tonight, and its not possible for me. i dont know about anyone else but when i put them rods down, when i go to shut the hood it wont close. the nut that holds the bracket on the hood hits off the damper thus not letting it go down. it opens much more nicely rods down, but id rather be able to close my hood. rods up for me!
ahhh no ****, i must have missed that part of it ha. ill have to do that next time i get off work early and its still light outmcheddadi wrote:
Woah Woah calm down there little buddy... Others are waiting too just be patient I don't think Josh and Kyle will let us down.rjdmmfl1 wrote:WHERE ARE MY HOOD DAMPERS????
Was told last Monday they'd be shipping on Tuesday, then told on Tuesday it'd be Thursday, then told on Thursday itd be Friday or Monday.....
"Little Buddy".. dude, I don't think you know me like that... be easy!windex wrote:
I have no problem waiting for the hood dampers, I just don't like being d!ck around... this day, no this day, no this day, no this day... finally Kenny from Stillen called me this morning and told me that the arrival date for the dampers is up in the air, and they didn't know when they would be in... I can live with that, that's perfectly fine, I just don't like being lied to! Had they told me that from the beginning, it wouldn't be a problem!LongBeachCoupe wrote:To some people... calling them "little buddy" may be sending the wrong message (especially since Dr has bigger wheels than you lol)...
Waiting patiently is a virtue...
I choose to wait impatiently, and for some reason it works out better for me that way! lol, i have my hood dampers!
Its not about getting upset, you just need to watch how you address people... give respect, get respect, give something else, get something else!windex wrote:I am being easy... Not trying to butt heads just stating that I'm also waiting; waiting patiently.
Its just the internet no reason to get upset.
Modified by windex at 2:20 PM 4/14/2008
Sorry that you felt that you were disrespected by my comment...rjdmmfl1 wrote:
Yes, I did it just like you. Did not remove the little plastic walls.mcheddadi wrote:
like remove the little plastic walls at each side of the hood like in the instructions?
the only thing I cut was the plastic upper part on the headlight to fit the lower bracket
Function over looks. I twisted all the way into the ball-joint. That is way they don't line up.It really doesn't bothers me at all. I am not sure how many times I will open the hood. , and I am not into shows...LongBeachCoupe wrote:... I assume they dont need to be twisted all the way into the ball-joint thing because if they are, they dont line up... I have mine loosened slightly so the STILLEN logo faces inward..
