sr20's Post your track times!@@$@%
strikingimage240
Car: my car
i ran a 14.4@99mph. My 60 foot was a 2.1 on cooper cobra tires(****ty). I couldnt get more than a 15.1 with 30psi in em so i lowered them to 19psi. My mods are93 srstock boostall emissions removeddenso step 1 colderblitz 3inch d pipejwt pop charger3ich open exhaust(no muffler)on an open diffi was not impressed.......... i got a new spec 4 six puck and have boosted to 10 lbs on my smic. I feel and hope that i will get a 14 flat. If i am lucky i hope to get a 13.99 and ill be satisfied
sr20det
Car: Drifting, draging, silvia projects
i ran 13.8 at 90.89 mphdial = 14.00r/t = .22560' = 2.125330 = 5.8301/8 = 8.880mph = 80.891000 = 11.4781/4 = 13.841MPH = 90.89
i went to 3rd gear than didnt shift to fouth cuz i was winning in 14 sec class.
sr20det
PS... how do you guys do it. i mean i got s15 turbo boosting at 13.5 psi and i still hit 13's ??? how do you guys hit 12's with t25 trubo at 14 psi and i only hit 13's ????
is it because of my 18" rims ? i got vlsd. blitz fmic, safc, blitz sbci-d, hks ssq bov, straight exhaust pipe 3", 300zx mafs, and 255 lph feul pump.
mynismo
sil80 power
fmic, custom 3" downpipe/exhaust, blitz ecu, nismo clutch, air filter. that's it @12psi on a manual boost controller falling back to 10psi.
you guys have much better tires then i did. i had 195/60/15 all season firestone firehawks m+s and was running open diff, chirping every gear. i dumped the clutch at 2800 and lowered rear tire pressure to about 22psi. very crappy non-prepped track. i took it to norwalk about a month ago but only got in one run and it was 13.7@105 with a 2.3 60'.
well i sold that car... my other one should be done in a couple days. hoping to trap 110+ due to having a flywheel, header and a greddy profec b spec 2 @ 14psi with better tires i've got. i'll report back in a couple weeks after breakin is done and i've got the ebc.
240SXer
Car: 1995 240sx SE (2jz powered)
No traction sux. A dude was at the track with a 427 Twin Turbo Zo6 (lingenfelter) corvette (mid/high 9 second car) he was running 12.0@127mph 11.8@133mph 13.1@124mph
Good times for shifting out of first and second at 3k ;) haha.. My dream car.. ahhhh
240SXer
AWD isnt the end-all of traction people make it out to be. Running my 245/50R16 Nitto NT555Rs I have yet to be beaten off the line by any AWD car. I'm only getting 1.8-1.9 60fts. Yes, AWD CAN be fast off the line, but what self respecting AWD owner with a 20-40k car is willing to do that much damage to their drivetrain? AWD trannies don't last long, it's common knowledge, if you want it to last you don't launch it hard.
Wait a minute. You have all this traction and can't launch your car hard or it'll break? Ghey!
f150intally
I cut a 1.4 60 ft time on drag slicks in a stock bodied S13.
I went 13.01 at 105.5 on drag radials with a 1.84 60 ft. Stock turbo running 14.7psi.
On 22" slicks I went 13.04 with a 1.448 60 ft. The reason I didn't run 12s was because the top speed limiter cut me off about 100ft before the end of the 1/4. Here are my timslips.
Mods are listed here.
I'm #402
mynismo
f150.. what do you think you'd do on regular street tires? also you may have hit speed cut on your dr run too. your mph is faster than your slick run where you said you hit limiter.
and 240SXer... how many psi were you running on the gt25? f150 ran almost a half sec better with his stock turbo and dr's. something doesn't seem right. you should be trapping 110+ and running mid 12s (at the very least). even if you were running about 14psi you should be in the 12s.
f150intally
mynismo wrote:f150.. what do you think you'd do on regular street tires? also you may have hit speed cut on your dr run too. your mph is faster than your slick run where you said you hit limiter.
I'm not sure. I never wasted my time running regular tires at the track.. I bought a second set of stock alloys and mounted the bfgoodrich g-force drag radials. I run those on the street when I'm looking for trouble.
I would probably run a 13.5-13.8 on normal street tires, maybe. I cut a 1.79 on my drag radials last time at the track. the 1.84 was the first time at the new track with drag radials. When running with slicks i averaged 1.706 60 ft time. That was out of 6 runs.
Most average drivers will not be able to get a 13.0 or a 12 out of the stock turbo. It takes alot of practice. I have over 40 passes on the car.
red240sx sr20det
13.831 at 103 my 60ft was 2.112 with a .686 reaction time 10lbs of boost but i think my gauge was off. im going to the track either wensday or friday so it will be fun after all i just got done to it
mynismo
what are your mods?
bootman
I ran a 14.2@101 2.333 60ft I slipped the clutch at 3000rpm and the car just hopped dose that mean that I need to slipp it at a higher rpm to get the wheels to spin a little?
Nismo_Freak
Car: 89 Nissan 240SX
Less arguing, more time slips.
K, thnx.
IBthisthreadgetslockedcauseofDSMvs.SRarguement. ;)
mynismo
it would help if people posted their mods as well as timeslips...
red240sx sr20det
my mods are hks intake,bov, tanabe 3 inch exahust no cat, 3 inch front mount intercooler, 3 inch downpipe, and i only run 110 octane at the track. i just got a boost controller i ported my stock exhaust manifold and put a exhaust to turbo gasket on that wasn't there when i ran the 13.8 im going this friday so it'll be intresting
nismostate
Car: all sorts of motorsports
Did pretty good my first time to the track. My last run was the best. was running 14.1 the whole night with 11lbs but raised it up for the last run.t25,smic,turbo back 3",93 octane, walbro 255, mbc, falken ziex 512 @ 32 psi, open diff and ksport coilovers. boosted at 14-15psi, saw it coming down to 14 so im not real sure. ran about 9 times. best time i got:
Last Run: R/T .184 60' 2.3211/4 13.783MPH 105.93
My alignmnet isn't perfect btw and I know if I improved my 60' it would of been a lot faster.
sr20det
sr20det
sr20det
sr20det
omg is upside down
sr20det
busky2k
13.41 @ 105 mph, 2.27 60ft. That was about a year ago, when i had about 40hp less. Hopefully I'll break into the 12s, with the stock T28 turbo! Cos since then I have added a Blitz FMIC, Bosch 040 pump, 3psi more boost, Equal length turbo manifold and better tyres!! Btw I have an S14 Silvia (In Australia hehe)
f150intally
busky2k wrote:Hopefully I'll break into the 12s, with the stock T28 turbo!
I would hope you can run 12s on that turbo! i ran a 13.0 on the stock t25.
kppk1986
My GSX runs 11's
Morph
Car: 91 Sr Powered Coupe
kppk1986 wrote:My GSX runs 11's
Well if it didn't id'e probally slap you. But then again Every tuned Gsx or Tsi does run low 12 or 11's.
sr20det
how many lbs do you have to boost to hit 11 on your GSX ?? just wondering because my friend got an gsx and he's gaol is to hit 11's on stock block and head, Just turbo upgrades right now his is doing 18 psi and he ran 13's so just wondering how far do he have to go :)...
kppk1986
that was my lame friend do not listen to him he is slow as hell and the fastest hes ever run was a 15.1 and supposedly he missed 2nd gear..
sr20det
so, you saying that " kppk1986Intake/Exhaust
Registered: Jun 2004Location: atlPosts: 66Car: 180sx My GSX runs 11's" <---- this is not you???? so you also saying your friend use your account to wrote that here ? and he slow gsx ran 15.1 while he said he ran 11's ???? is that what you trying to tell me ????
soflajdm
11's have been acheived by hitting 21psi on a stock "looking" turbo in GSX's
i myself have run a 13.564@104 with the following mods:
Red TopHPI FMIC3 inch turbo back exhaust (GP Sports Spec D)stock turbo at 15psi
and a couple of other minor things that i dont feel like listing
btw, stock diff, bald *** 205 tires as well got me a 2.0 60'
kppk1986
no no my friend got on under my name and posted..
