Enlighten us, Bob.sideshowbob wrote: ... i know how to get 200 hp @ the rear with no nitrous or turbo.
this is kind of childish don't you think? either post what you think you know, or stop posting all together.sideshowbob wrote: It's rather easy to explain and you would agree if i said how. It's not really for the do-it-your-selfer though. I'm not saying though!
wow. maybe you should reread what he said.InsanityInc wrote:I'm going to have to call BS on those equations. I've seen stock KA's that put out 130+whp, and there's no way in hell a stock KA is anywhere CLOSE to 100% VE.
sideshowbob wrote:dev ..200whp is no big deal. I never said is was. I have an automatic and i doubt i'll swap it over, but you never know.orion...you wanta cough up some money?? Someone gotta pay russ's bill. I know of another part that can be custom built for the nissan that'll add at least 2-5hp for $8.00(retail) and it's not computer related.If no one has cash...oh well! If i said how (to get to 200), everyone would say.........WELL DA !! but it has a plus side to it (the way i'd do it).......case closed
Hey, not "my" formula...it's the commonly accepted formula used for HP calculators an such, and it's pretty accurate.InsanityInc wrote:Maybe you should comprehend what I said:
According to your equation, a stock KA24DE with 100%VE will peak at 128RWHP. Therefore, a stock KA24DE with less than 100%VE (we can probably safely assume about 65% at best), would have far less than 128RWHP. However, I've seen a number of newer stock KA's that put down 130+ RWHP, meaning they magically have more than 100% VE in stock form.
That, or your equation is bunk. Guess which is more likely?
Correct...I got caught up trying to make a point and "slipped"...my bad.InsanityInc wrote:Not to mention that your equation is supposed to be crank HP, which makes it off even further...
Now here's where you are sorely mistaken...InsanityInc wrote:Heh, you really think a stock engine gets anywhere near 100%, or even 90% VE? You're sorely mistaken. 65% is about the average(and that's at the TORQUE peak, horsepower has little to do with VE directly). Generally lower for larger engines (really, really low for some old, large engines, like 30% or less).
+100% VE is not uncommon for a mildly modded motor.InsanityInc wrote:Also, most KA's with decent milage make 160+whp with I/H/E, and they're definitely not over 100%VE. Not to mention that a N/A KA is never going to achieve good VE at a decent RPM with the stock manifold, it's a physical impossibility.
InsanityInc wrote:Heh, you really think a stock engine gets anywhere near 100%, or even 90% VE? You're sorely mistaken. 65% is about the average(and that's at the TORQUE peak, horsepower has little to do with VE directly). Generally lower for larger engines (really, really low for some old, large engines, like 30% or less)..
Modified by InsanityInc at 2:51 AM 11/2/2004
