240life »
https://forums.nicoclub.com/240life-u76914.html
Thu Jun 26, 2008 2:54 pm
Brand new NISMO FPR set at 43psi, it now starts then stalls immediatelly, I also get no response from my throttle, it just stalls instantly. I have reset the timing, CAS and they are good. I replaced the following items, intake gaskets and cleaned my IAACV, replaced all vacume lines, re torqued all FMIC pipes. replaced 2 injectors, all injector o-rings, my fuel pump sending unit, got a new MAF from a SOHC, all new fuel lines and filter, complete tune-up. Tested all wiring to TPS, tested my TPS with the following results: 5.12 fully closed, 4.7 partially closed, and 1.72 wide open isn't that backwards? I ordered a new TPS just in case.All my injectors fire a great pattern, I have spark across the boards and the car runs, idles great off of ether or for the first 2-5 seconds before it stalls. I have been in the FSM for 2weeks and am now about to say i am frustrated beyond imagination:bash And to make it worse Jeff at Heavy Throttle says I have a newer black top E5 ecu that don't come with a light for checking codes Any and all help is appreciated.
