The D-Jetro Power FC is not MAF limited, but yes the other versions are.GTR PrYdE wrote:I hear about more tuners using AEM than PFC... but I believe because the PFC is Maf limited...
Touge’ wrote:The D-Jetro Power FC is not MAF limited, but yes the other versions are.
With an AEM ems can you set things like rev limiter, speed cut, turbo timer and whatnot? Just wondering
with NDriftBoy07 wrote:hell yeah man! bout time you updated this project! lol cant wait for the vidswhen do you plan on driftin her??
Only reaseon i took to engine logics is cause brad the tuner I personally know him and hes the best with SR20's and 240's when it comes to tuneing so it just made me more comfortable to go to enginlogics!! I cant wait to see what it will make, I hope the block stays strong like it is... keep your fingers crossedGTR PrYdE wrote:Badass Jordan, glad you finally dropped the car off. What happen with secret services?? Either way Engine Logics is supposed to be real good too.I wonder what you'll make on that heartbreaker dyno
Thanks man, I say just get your suspension stuff done and the n have fun with what you have for a while and if you would like to have more go bigger with whatever you like.DriftBoy07 wrote:thas really exciting dude congrats! lol i wish i could be doing anything with drifting right now..lucky! im debating between an S15 turbo with supporting mods to get a lil over 300hp..or go all out on suspension & stick with 250hp with bolt ons/boost controller
make sure you post vids asap!
No i didn't!CoupedUp wrote:Did you consider the Electromotive TecGT? It ran me about $2200 for all sensors(MAP, IAT, CLT and MAG Sensor) and unterminated harness.
All the benefits and technology if not more of the AEM, but has more tunability features as well as a higher resolution timing map by using an inductive 60 "-2" trigger wheel.
It uses the same ignition/timing system(trigger wheel and mag sensor) as the Formula 1 Pectyl ECU.
Very powerful and badass Stand-alone. It has the processing power to support processing all the injectors and coil packs at 20,000 RPM. At 10,000 RPM a revolution happens in 6 ms or .006 seconds. Its just crazy what the standalones can do in such short periods of time at certain accuracies.
^ No, he didn't...CoupedUp wrote:Did you consider the Electromotive TecGT?
I know, but I didn't know what kind of response that was...like..."No I didnt!, how dare you say something is as good or comparable to AEM."datsun2401972 wrote:
^ No, he didn't...
I was waiting for someone to point our the differences between AEM's system and other hardcore systems that have been on the market much longer than AEM's...thx!
Ummmm!!!! Yeah last time I check this was my thread so if you dont like what im doing then screw OFF!!!CoupedUp wrote:
I'm from Broken Arrow, OK. BTW.
What the hell? This isn't h240 he just asked a question??Slideways^Jordan wrote:
Oh da baby...Slideways^Jordan wrote:Ummmm!!!! Yeah last time I check this was my thread so if you dont like what im doing then screw OFF!!!
Sorry i didnt really understand how you were asking the question but im sorry i dont want to be rude so i apoligize...CoupedUp wrote:
Oh da baby...
No, I understand this is your build thread. I never said I didn't like what you were doing.
Just curious was all. Anyhow...congrats on approaching the day to drive it again.
the head is where i would expect to make all the power, its not like eagle rods and cp pistons would give him more hp, it would just allow for more power to be made and reliably. with the turbo,manifold,injectors,272 cams and other supporting mods i would expect massive ammounts of power (450+)Stripes wrote:Its mostly the head that he built though, so you can't expect massive amounts of power, although I thought he'd be closer to 400whp because of the turbo and injectors he went with.
I guess I didn't word it very well, but this is exactly why I said I wouldn't expect massive power. Sure he could max out his setup with 400+, but it wouldn't be too smart because then how reliable would the motor really be?gixxerbob wrote:the head is where i would expect to make all the power, its not like eagle rods and cp pistons would give him more hp, it would just allow for more power to be made and reliably......(if cody built the bottom end for another 2k$ he would have an extremely reliable 400hp build for a very reasonable price.)
Thanks man i appreciate it alot , I absolutly LOVE my Top speed intake manifold the casting in some areas of the manifold are few tiny hairs off.Stripes wrote:Its mostly the head that he built though, so you can't expect massive amounts of power, although I thought he'd be closer to 400whp because of the turbo and injectors he went with. Either way, it's still a very nice build and I'm sure it runs extremely solid with the setup he has.
To Jordan,How are you liking that Top Speed manifold? I came across it one day on Courtesy Nissan after searching for months for an affordable short runner manifold and I'm thinking about getting one. Congrats on getting your car running good!
CoupedUp wrote:Cool...you shouldnt be hitting 90% duty cycle at at 301 WHP...you shouldnt even hit that on some 550s...
I wouldnt jump up to 1000s...Id make sure they're really 810s... The bigger the injector the harder it is to control at low millisecond pulses.
Awesome, congrats on getting your car back!!! I bet it must feel great!
Yea, HLAs can collapse at higher RPMs because they don't have time to refill.
On this dyno I bet 550's would hit close to 90%, but still there's an issue somewhere.As for the power it made, 358 dj is very nice at 12psi!CoupedUp wrote:Cool...you shouldnt be hitting 90% duty cycle at at 301 WHP...you shouldnt even hit that on some 550s...
