Are you really bored with it already?QR25DE wrote:I'm bored with 7psi, someone run 10psi on theirs and let me know how it holds up. K thx.
Hes just been in faster. It works well. There are still gains to be seen without upping the boost. Better flowing exhaust will help for sure, but you definitely don't need it to spool any sooner.dldjros69 wrote:
I sure hope not!!!
Haha thanks Scott, but yeah, sell yourself. Time for better flow. We'll do that, hit the dyno, then talk about upping it.QR25DE wrote:
Yeah, *sells self to buy exhaust*
Did you order the new intake yet or am I doing that? Lol
Edit: PS. I swear to god if you make me pull that engine to build the internals you'll be doing lsd at the same time.
Modified by mik101 at 7:47 PM 1/30/2010
I would change them to something ala SPEC-V springs while we're in there for reliability's sake, but without a way to raise the limiter (atleast without getting something like the powerpup again) or without a standalone to properly support this engine he's probably pretty much SOL for that. For someone willing to mount their own crank wheel and pickup to get a more 'normal' signal then I'm sure standalone is an option (if you can control the dbw throttle). There are so many things to take in consideration, which makes working on this slightly more difficult than others. Not that the Nissan world ever has it easy (if you dont have a vq or something of skyline/sylvia lineage).JDRosenberg07 wrote:Yeah dude change out your exhaust first.. You'll easily get 20 hp just by doing that especially with your turbo. I would hold off and see how the engine holds for a while on 7psi before upping it. Oh and if your gonna end up doing the interns def upgrade the valve springs.. You'd be able to more safely raise the rev limiter that way and get an extra few hundred rpms of peak power
Not a question of what I want to do, it's a question of what I can afford. lol.mik101 wrote:I know the balance shaft removal kit no longer works on the newer motors. It even appears the sparkplug size is different. BKR7E-11s didn't fit in the Altima, but I see people using them in older QR25DE turbos in SERs. The plugs in the Altima's QR25 were smaller.
I'm sure CP or another manufacturer can make something if I'm able to provide specs or have a piston to base it on. We'll have to see down the road what Scott wants to do. It's not my car afterall.
Spark plugs:mik101 wrote:I know the balance shaft removal kit no longer works on the newer motors. It even appears the sparkplug size is different. BKR7E-11s didn't fit in the Altima, but I see people using them in older QR25DE turbos in SERs. The plugs in the Altima's QR25 were smaller.
QR25DE, even though SFR just came out with a turbo kit for the 2.5, it must feel good going through this on your own and having it come out nicely!!! Kudos to you my friend, this thread will hit 20,000 view soon, but it is already epic!!!!QR25DE wrote:New boost gauge to replace the condensation trapping, needle not working other one!
Yes I'll get a better pic once it's actually powered and working. Too cold in the garage tonight -18oC outside. Brrrrrr...
what kinda gauge is that?QR25DE wrote:New boost gauge to replace the condensation trapping, needle not working other one!
Looks good, now go change the AEM face/bezel to match it. :P Yeah I'm picky. We'll wire that gauge up later today. Yay no more vacuum hose running through the firewall.QR25DE wrote:New boost gauge to replace the condensation trapping, needle not working other one!
Hells yes... without labor, but labor was pretty much free with myself and my friends. Mike ^^.Importroller wrote:I'm impressed. Good job on the fab work. I didn't read all 9 pages, so were you able to do this under your $2800 limit?
This is the beggining of the end for your motorQR25DE wrote:I'm bored with 7psi, someone run 10psi on theirs and let me know how it holds up. K thx.
Lol shhh.... I expect him to put out his clutch first anyways.adidas2go wrote:
