scc s13 lays down 274 hp
mattback
Car: being a big f'ng ricer
pampadori wrote:after some research, i found out some info on the gt25r...the part number listed above for the gt25r and gt28r are for the baby turbo gt25 and gt28 models.
they are only good to those hp claims mentioned in the same post.
but garrett also makes the gt25r with the much larger to4s compressor housing and wheels to fit them. these wheels flow the 44lbs/min mattback was mentioning. these are alo more expensive.
this gt25r is rated at 380-400hp....705330-0001this gt25r is rated at 400-440hp....705330-0002
the only difference is that 0002 has a .86 a/r on the turbine side. the 0001 is a .64 a/r. the wheels are identical, as is the compressor housing. (to4s. wheel flow 44lbs/min) c.h.r.a. is the same aswell.
btw, the to4s housing will probably not fit on the stock manifold. it will more then likely hit the manifold on the cyl1 and 2 runners.the exhaust side inlet flange is a t2. but the outlet may or may not be the same. the pics i saw did show a internal gate with a 5 bolt outlet. suggesting that this will be the same, or very very close.
i hope i helped some people out. the gt25r seems to be the name of many different turbos. so i suggest if anyone gets on of these, they order it and research it by part number.shaun
The GT25R iwth the .86 fits under the stock manifold.
pampadori
Car: 91 Nissan 240SX coupe
mattback wrote:The GT25R iwth the .86 fits under the stock manifold.
Which one? the one with the to4s compressor? or 250hp version?shaun
kingjag88
Car: 1990 Nissan 240SX (project 1), 1967 VW Beetle (project 2), 1984 VW Rabbit Diesel L (Greasecar!)
Quote »they are using a KA ECU[/quote]
sorry this quote is a few days old but i was under the impression that the ecu they were using is a reprogrammed sr20det ecu? oh, and scc paid 1500 for their clip, not 1200:)
