bllabong89 »
https://forums.nicoclub.com/bllabong89-u142191.html
Fri Jan 29, 2010 8:34 am
I got some more work done on the front bumper. First I got the headlights, corner lights and old bumper off to test fit the Origin bumper. After I put it on and set the lights into place, I noticed that it would need a little work done but what doesn't now-a-days.
The next thing to do was get the bumper support in the right spot. I had to loosen the 4 bolts that holds it on and push the support down to get the bumper to sit a little bit lower. Because of the mounting brackets on the new bumper, it pushed the headlights up and wouldnt allow the hood to shut properly. Once I got that done, I started on the fender mounting points.
I took out the plastic screw mounts from the fender first. After they were removed, I used a pencil to draw the square cutout of the fender. I used my foot to hold the bumper up and one hand to hold it in to my choosen location. With my free hand, I took the pencil and traced the square on to the bumper.(It took more than one try so just do it until you get it where you want it)
After that, I used the mounting clip for a template. I centered it on my traced square and than drilled out the hole.
I found that it was easier to use a uni-bit after the pilot hole was drilled (I started with the smaller drill bit and when i moved a size up, it began to chip the fiberglass so I used a uni-bit and it solved the problem).
Once the holes were drilled out to the size of the screws, I placed the bumper back on the car and began to screw the corners in.
And this is what it looks like. I still need to finish some mounting tabs for the bumper support but it is actually pretty solid with the two screws in alone. And sorry for the bad pics, I was using my phone and its hard to get a pic of the front because Im kinda cramped in my garage
Rawrrrr...
Oh, and lonismos14 let me know if you get that body kit
