Just curious, why do you think Bose sucks?Darthswan wrote:Yeah, this is a journey I'm heading on. This was the only reason I didn't want this car. Bose suck. I see so many challenges. I have no problems doing a rewire, it just the number of amplifiers it would take to power all the replaced speakers.
I'll check out that link
All of my cars have had aftermarket stereos. To me, Bose lacks crisp highs and sufficient lows. I would rather have a base system that i could update later.deeselcyde wrote:Just curious, why do you think Bose sucks?Darthswan wrote:Yeah, this is a journey I'm heading on. This was the only reason I didn't want this car. Bose suck. I see so many challenges. I have no problems doing a rewire, it just the number of amplifiers it would take to power all the replaced speakers.
I guess I'll start with the sub. Anyone use AudioControl? Did you use the factory location or a separate box?DoN_BLaZe34 wrote:I agree with Swiss. When I had my M45 adding a sub along with changing the front tweeters that are inside the rearview mirror enclosures was enough to make me not rip out the entire system.
If you're determined to go the entire gutting route I believe there are a few guys with the older M's that have done it. I'll see if I can find the thread(s).
Here are a couple of threads that were started but neither of them never finished with details.Darthswan wrote:I guess I'll start with the sub. Anyone use AudioControl? Did you use the factory location or a separate box?DoN_BLaZe34 wrote:I agree with Swiss. When I had my M45 adding a sub along with changing the front tweeters that are inside the rearview mirror enclosures was enough to make me not rip out the entire system.
How did you run RCA wires to the sub amp? I know in the G, you had to tap into the signal out from the factory amp to get signal to an aftermarket amp.coolchuck wrote:There are sooo many challenges with this system. Active noise cancelling, Voice control, voice directions from Nav.
I put a sub in the factory position. it wasn't an open air sub so it didnt really sound good. It didnt hit right on certain frequencies. Plus, it needs to be shallow mount to fit the factory space properly.
Next I put my sub in a box and reconnected the Bose speaker. Sounded great when I wasnt getting feedback from active noise cancelling, which was about &0% of the time. So I disconnected the Bose speaker again. Much more bass. My only gripe right now is lack of sound control. I think an Audiocontrol unit will take care of that.
People have been talking about the sound limit on the sub and it goes away the more you turn the radio up. Are you experience that same problem, or any problem, with running the signal off of the 10" sub line?coolchuck wrote:My Alpine amp has speaker level inputs so I'm using them for now. I tapped the signal that goes to the 10inch speaker in the back. To use the RCAs, your amp has to have switchable voltage. Alot of the G guys are running JL Audio amps that only have RCA connections but have switchable voltage.
I'm not super familiar with the M audio set up, but I did have BOSE in the G and I was able to run an 600W Alpine monoblock (old model) just by tapping an RCA wire from the signal out from the stock amp. As far as I know, you can't change the voltage on that amp.coolchuck wrote:My Alpine amp has speaker level inputs so I'm using them for now. I tapped the signal that goes to the 10inch speaker in the back. To use the RCAs, your amp has to have switchable voltage. Alot of the G guys are running JL Audio amps that only have RCA connections but have switchable voltage.
Not sure about the M's audio set up but in my G, there were no issues turning up the sub to a point where it was ridiculously loud. The sub volume is usually modulated with the amp settings (gain output or whatever else the amp uses to control sound) in this kind of application. I would imagine the M's system would work similarly.Darthswan wrote:People have been talking about the sound limit on the sub and it goes away the more you turn the radio up. Are you experience that same problem, or any problem, with running the signal off of the 10" sub line?coolchuck wrote:My Alpine amp has speaker level inputs so I'm using them for now. I tapped the signal that goes to the 10inch speaker in the back. To use the RCAs, your amp has to have switchable voltage. Alot of the G guys are running JL Audio amps that only have RCA connections but have switchable voltage.
I My understanding is the speaker signal will give you a high voltage signal, thats why I used the speaker connections instead of RCA.SwissCheeseHead wrote:I'm not super familiar with the M audio set up, but I did have BOSE in the G and I was able to run an 600W Alpine monoblock (old model) just by tapping an RCA wire from the signal out from the stock amp. As far as I know, you can't change the voltage on that amp.coolchuck wrote:My Alpine amp has speaker level inputs so I'm using them for now. I tapped the signal that goes to the 10inch speaker in the back. To use the RCAs, your amp has to have switchable voltage. Alot of the G guys are running JL Audio amps that only have RCA connections but have switchable voltage.
I've debated throwing a 10" in my car but I don't want to lose any trunk space, and with my 1yr old in the back seat, I wouldn't be able to really turn in up half the time anyway.
Have you tried looking in the FSM? There are a lot of techie bits in the FSM and I'm sure the resistance of a speaker is in there. Should be anyway.IlyaKol wrote:Okay...so, bumping this.
I want to try replacing just the sub in the back with a smaller one that fits...I need a 2Ohm one right? That's what the BOSE system uses? Also may look into doing just the door speakers as the OP did...also 2Ohm? Have we confirmed what size they are (6.5" or 6x9)? Also, the RMS of the stock amp? Thanks!
This is my initial selection, things might change but I'm pretty sure this may be it.IlyaKol wrote:Mind listing your 'shopping cart'?
If you want to keep your complete factory set up and just add a subwoofer, you should be able to do so relatively easily. The only line you would have to run is the power wire from the battery to the aftermarket amp. Everything else should be accessible from your trunk.IlyaKol wrote:Ahh your not doing a thin-mount sub? I'm going to talk to someone at Crutchfield eventually about that and see what they recommend. I don't want to run any wires, etc. I just want to plug'n'play and squeeze out any performance I can get.
I'm more concerned with the trunk space as I occasionally need it. Although, I could get one of those prebuilt JL boxes with the sub (Audiobox? might be the name) that I had in my old Maxima and just add a 1 channel amp to it. It wasn't relatively huge, but still wasn't small.SwissCheeseHead wrote:If you want to keep your complete factory set up and just add a subwoofer, you should be able to do so relatively easily. The only line you would have to run is the power wire from the battery to the aftermarket amp. Everything else should be accessible from your trunk.IlyaKol wrote:Ahh your not doing a thin-mount sub? I'm going to talk to someone at Crutchfield eventually about that and see what they recommend. I don't want to run any wires, etc. I just want to plug'n'play and squeeze out any performance I can get.
Honestly, this is better than replacing the factory sub because having an aftermarket sub powered by the factory amp will not increase the volume or thump. You will need an aftermarket amp providing more power (than the factory amp can provide) to increase the thump.
When I get time. I can post what you need with schematics if anyone is interested.
