10" Bose Subwoofer Replace on 2012 M37-S
Lefort76
Car: 2012 Infiniti M37S
Thinking on replacing this Bose sub for one 10" Alpine SWR-T10
Since I don't like the Idea of loosing trunk space or much worse.. The rattle sound, I'm planing to replace the original Bose sub and place the new Alpine in the same spot with a very flat fiber grass enclosure.
Any ideas or suggestions will be appreciated. ;)
10" BOSE flat subwoofer 2012 Infiniti M37-S
10" Alpine SWR-T10
I will keep you posted. :dblthumb:
DHCrocks
Car: 2012 M56S
2004 G35 Coupe
Are you planning on adding an amp? or will you run it off the stock amp. My concern is the noise cancelation system they have, I want more bass too since the stock sub is not that great but the noise cancellation system uses the speakers and if you add an amp it might throw off the balance of the system and you might get noise out of the sub since you will be ampliying the signal and increasing the volume of the NC system.
06M4.5
Car: 2006 M45
in for pics
I plan on doing this to my 2006 M45
kermit the guy
Car: 2008 infinity M35 Sport
replacing-the-stock-10-sub-woofer-testi ... 36723.html
heres a post i did about replacing the subs
Lefort76
Thanks Kermit! very helpful :dblthumb:
ok, what I'm planing to do is to replace the bose amplifier with an Alpine system. and since everything is in the trunk I don't have to touch the dashboard. All I need is the power from the battery and we are in business!
this is the equipment I will use:
Alpine PXE-H660
http://vault.alpine-usa.com/products/do ... E-H660.pdf
for the Sub :
Alpine PDX-M6
600 Watts RMS
And for the speakers:
Alpine PDX-F6
Power rating 150W x 4
Lefort76
DHCrocks wrote:Are you planning on adding an amp? or will you run it off the stock amp. My concern is the noise cancelation system they have, I want more bass too since the stock sub is not that great but the noise cancellation system uses the speakers and if you add an amp it might throw off the balance of the system and you might get noise out of the sub since you will be ampliying the signal and increasing the volume of the NC system.
you are right! Thats why I'm using the Alpine PXE-H660.
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
where were you planning to put (hide) the amps?? since those amps are really small, you should still have lots of trunk room -- if you install them in the trunk...post pix when finished...
Darthswan
Car: 2012 M37X
99 Nissan Maxima
any updates?
mrnix
Car: Currently 2012 M37X, Malbec Black
Formerly 2004 Infiniti G35 Sedan
bump for any updates, it's been a while on this one.
