ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Fri Aug 15, 2008 8:52 am
I run an Innovate LM-1 (since it first came out serial #0002). I have always religiously replaced my used sensor with a brand new one before a major tune or remap. Although you can recalibrate the LM-1, I have compared results to a sensor that has been used for a couple race months (then recalibrated) compared to a brand new recalibrated sensor and found they could read .25-.5 off. In motors like ours that continually see high amounts of boost and very rich mixtures often, the carbon and heat eventually over powers the sensor causing it to read inaccurately. If you daily drive and cruise the vehicle, then the lean cruise mixtures should clean up the build-up if it isn't too much. My daily drive sensor was just as accurate as a brand new sensor, where as, my race sensor which only used for a couple months (twice a week, weekend track events) was inaccurate up to half a point. So here is what I ultimately ended up doing with my stash of sensors. One for DD, and one for dyno/street tunes. When the tuning sensor stops reading as accurate as the DD one, I chunk it and get another one. For race events, I put a plug into my front O2 bung (3 inches away from back of turbo) and installed it way down at the end of the down pipe. For the higher accuracy for tuning and street, I use the front bung since it can respond and sample exhaust gases right as they exit the turbine. Keep in mind, even if it is a daily'd sensor doesnt mean it is great. A poor tune in that department can make it kill sensors just as fast.
As for your pistons, I would read that as a lean condition, particularly during spool up (boost threshold). During torque peak is when an engine is vulnerable the most. Torque peak on boosted engines is usually during max spool or just after it. This is when heat is built up the fastest and can really wreck internals if not taken care of. The intake side of a piston is usually the first to go. It is the first and last of it all. When intake valves open, the air mixture will tend to do a horizontal roll into the cylinder towards the center and into the cylinder wall of the exhaust side. Picture a water slide when the intake valves are opened. Now as the piston reaches the bottom and begins to come back up, this rolling motion becomes a wave bouncing back to the intake side. So as it is ignited, the flame will travel will go normally right down the center til the end of the flame, a violent burst right at the end (lean trail left behind resides under the intake valves). This intense heat overwhelms the entire combustion chamber until the exhaust valve opens. The exhaust side of the piston is evacuated first so the intake side is last to go. Now the intake valve is opening again with some valve overlap to cool and bring in a fresh new charge (if your injectors are advance timed enough). The thing with valve overlap is, it only cools the center and exhaust side (oh bummer, that corner under the intake is still hot). In comes melting pistons, slowly but surely. Now go back and look at the plugs you posted pics of. I see goose bumps on them. If you clean the plugs entirely without scrubbing them, these goose bumps might be silver/gray. These are a sign of eroding aluminum from the piston having to travel across the plug to get out the combustion chamber and eventually some of them stick to it.
Now go back to this valve overlap issue. Valve overlap is just peachy for high performance motors since it has a cooling effect AND if tuned right, it carries in fuel/air mixture EARLY! This way your combustion chamber is filled with less used exhaust gases, since it was vacuumed out by overlap. Overlap is your friend in most cases, but if not tuned for, is your enemy in fuel injected vehicles. OEM ecu types have injector advance built in already and are good enough. When you go to a blank ecu and tune from scratch, often then not, you have to get injector advance in (usually has a degree map just like ignition). It times the injector to begin spraying at a certain degree of crank rotation. These values vary from cam to cam. If these values are late, then during that precious valve overlap, you are getting nice clean air (with no fuel!). These causes the edges of your pistons to have fresh air sitting there. Now during a normal burn, everything is all perfect til that flame reaches the edge of the pistons. Then suddenly a huge rise in flash heat right at the end cause the lean edges of air and no fuel. The wideband can't pick this up, because you can mask it by adding more fuel with a perfect AFR, but fuel still isn't added at the right time. So your mixture can read rich and you can still kiss your pistons goodbye because the lean edges after burned blend into the rich exhaust mixture making the gauge read normal still.
Now roll back yet again to your cam problem. When it was out of wack, this wasn't tuned for. Your setup, the problem can't be pinpointed because of the many changes it has seen since it has awakened, but we can narrow it down to a few choices. The category of the problem is definitely a lean condition. Sorry for the long post .
