ItzGenX wrote:That uneven compression across the board isn't so pretty either. The number 6 seems uber bad. I would have to guess that the rings were installed poorly (all gaps are lined up with each other), but when this is done, usually the compression isn't THAT low. The other thing I can think of is that whoever did the gapping of the rings did so impropperly (too small of a gap and they can bind up when they expand with heat). I knew it was a bit strange for you to be boosting more around 5k. My SR22 becomes an implosion machine at 4800-5k. Your 0.5L and 2 more cylinders should easily spool that turbo. If you are going to tear into it, might as well fix it and bring her back to life yourself. We'll help you in the process . That way, at least you don't have a mystery engine. You'll know if things are done right.
Thanks for the words. Honestly the boost seemed to be coming on later and later as time passed....
I no longer have a garage, I now have a driveway. I'll have to convince the rents to let me put her together in the single car garage if I decide to go that route. I've got other **** I need to currently pay for so tear down might not happen for a month or so. Hopefully I don't need a rebore, just a hone so I can reuse my pistons.
Care to share anymore info on piston ring/engine assembly I know a bit about it, but should know more of the technical stuff. I'll be sure to read up on it in the mean time.
