RB Classifieds - RB engine Parts Only
chad b.
Car: chocolate chip kouki
Contact: 251-508-0914
Price: $1200 shipped anywhere in the US
For sale: AEM EMS 6620. This stand alone ECU will operate SR20DET, RB26DETT, RB25DET, RB20DET, VG30DETT, and CA18DET. It is the version 2 and supersedes part numbers 30-1620,30-1621,30-1622.
The ECU comes with Intake Air Temp sensor, MAP sensor, boost solenoid, and an AEM 30-4300 serial gauge (19 gauges in 1). This is everything you will need minus a wideband O2. The system is on my car and works fine. I bought the ECU new a year ago. All together this is well over $2k.
For another $200 I will throw in my ChaseBays wiring harness (rb25det into s14)
chad b.
^^^^^ sold
meet07
Car: 89 180sx rb25det
I have a ton of parts that I have collected over the years. Some I kept for back ups and now I just want to clean up a bit. All prices are best offers and if you have any questions its best to contact me Via phone. You can call or just text and I will return the message.
Item:RB25det Freddy Intake Plenum
Description: Used without accessories
Price: $100.00 plus shipping
Pictures:
Item: RB25det IACV
Description: Used in working order
Price: $50.00plus shipping
Pictures:
Item: RB25det Air Regulator
Description: Used and working
Price: $50.00 plus shipping
Pictures:
Item: RB coil pack brackets
Description: I have 2 sets used
Price: $20.00 plus shipping
Pictures:
Item: RB CAS Brackets
Description: used no cracks
Price: $20.00 each plus shipping
Pictures:
Item: RB20,25,26 Water pump pulley
Description: Used not bent
Price: $10.00 each plus shipping
Pictures:
Item: RB20,25,26,30 timing belt drive gear
Description: Used all teeth
Price: $25.00 each plus shipping
Pictures:
Item: RB25det Timing belt covers
Description: Used
Pictures:
Item: RB25det rear main seal/bracket
Description: Used may want to replace seal
Pictures:
Item: RB25det oil pickup
Description: used screen no damage
Price: $25.00 plus shipping
Pictures:
Item: RB20,25,26 knock sensors
Description: Working used
Pictures:
Item:RB25det VTC solenoid
Description: used and working
Price: $40.00 each plus shipping
Pictures:
Item:RB25det oem head bolts
Description: used torqued once from factory
Price: $15.00 plus shipping
Pictures:
Item:RB25det Intake with pod filter
Description: Blocked off plumb back for bov. 15hp increase. Used for stock t28 turbo or similar
Pictures:
Item:RB20,25,26 Aftermarket Throttle Body 90mm
Description: same size as q45
Price: $30.00 plus shipping
Pictures:
Item:RB25det Thermostat neck
Description: used and no cracks
Price: $15.00 each plus shipping
Pictures:
Item:RB25det coolant hosed under plenum
Price: $40.00 plus shipping
Pictures:
Item:RB25det oil dipstick tube
Description: used
Pictures:
Item:RB25det Alternator/brackets
Price: $60.00 plus shipping
Pictures:
Item:RB25det Alternator bracket
Description: used
Price: $10.00 plus shipping
Pictures:
Item: AEM 6-1 Gauge part number: 30-4300
Description: New out of the box with all paperwork
Pictures:
Item: RB25det CAS
Pictures:
Item:RB25det O2 sensor
Description: just need pigtail soldered on
Pictures:
Item:RB25det valve covers red
Description: used with no leaks
Price: $50.00 for both plus shipping
Pictures:
Item:RB25det idle pulley and timing pulley
Description: used
Pictures:
Item:RB25det coil pack cover
Description: used
Pictures:
Item:RB25det coil packs
Description: used
Pictures:
Item:RB25det coil pack harness
Description: working no cuts
Pictures:
Item:RB25det fuel rail with 370cc injectors x 6
Description: without harness/ With Harness + 30.00
Price: $75.00 plus shipping
Pictures:
Item: Fuel rail only
Description: used
Pictures:
Item:RB25det oem t28 turbo with elbow
Description: Used, Making noise at 300hp, upgraded to bigger turbo
Pictures:
Item:RB25det Aftermarket 3 inch Downpipe
Description: Used for stock tune when upgraded to AEM. Has maybe 3 hours. Wideband bung welded in place
Pictures:
Item:RB25det OEM Clutch
Description: used with good looking pressure plate
Pictures:
Item:RB25det OEM Flywheel
Description: Good shape
Pictures:
E: [email protected]
M: 919-818-one eight sixty for
Thanks
datsunmotorsports
Car: 74 260Z , 71 240Z , 71 510 wagon , 68 Fairlady 2000, 82 Diesel Maxima
Contact: 831-402-5387
For sale:
-2 RB25 transmissions $900 ea
-4 RB25DET cylinder heads $40, $250, $300, & $500
-6 FMIC underversal $100-200
-4 or 5 RB25 valve cover sets $40 set
RB25de coil cover $50
-2 RB25det coil cover $50
aftermarket vented RB25det coil cover $50
-ISIS intake with RB25det injectors, Q45 TB, coolant passage, IAC, etc ready to bolt on $350
-Greddy intake also loaded with all parts ready to bolt on $900
-RB25/RB20 stock exhaust manifolds $40 ea
-Toyosports tubular Side mount RB25/RB20 exhaust manifold external 38mm wastegate plumbed. $300
-2 or 3 RB25det cam shafts(pairs only) $100 ea
-2 RB25det short blocks (pretty bare) $200 and $300
-4 PS pumps(these are for non-hicus) $100 ea
Shipping: Yes anything USPS will accept at cost to buyer.
RB24D
Car: 1996 rb25det 240
All parts sold mods please delete post thanks .
outlaw7
Car: 78 zed
RB24D wrote:Seth Ellwood
Columbia SC
Eight 03-587-5896
For sale
Rebuilt , match ported and polished head with intake stud kit still in bag 1,200 obo
Stock pistons 50
Freddy intake gasket match ported to head and powdercoated black never bolted up 250
2 sets of acl bearings 50 ea
1 ni oil pump in box 50
1 n1 water pump in box 50
1 stock water pump new no box 40
1 stock oil pump not in box new 40
Crank balanced shot peened cryo treated crank collar install never bolted back in 350 obo
block 20 over never bolted up after machine work 250
ac compressor with lines 75
alternator 40
starter 40
Wiring specalitys s14 rb25 series 2, 325.00
Painted valvecovers and spark cover with new gaskets 100
Painted timing covers 50
Gt40r (bad center section 150
ps pump for non hicus 50
ss down pipe 20
A ton of other items just ask I no longer have a need for any of this stuff
If some one is local and interested in the whole lot I will make them a screaming deal. I will try to get pics up this eve or tomorrow. I do not have a data plan on phone so no text.
Perfer local pickup for large items or can try to ship at buyers expense
I called you about the parts im interested in.
Dave
RB24D
got msg will contact today.
sickness14
Car: 95' S14 SE. RB25 Neo. ARP, Tomei 260's, HX40 Pro, PFC, Synapse, Greddy
delete
Largekid
Car: '96 RB S14 SE, '04 LS6 CTS-V
SOLD!
Contact: 317. nine seven nine. 35 zero two, PM on here, largekid02 at yahoo email
Price: $1050 Shipped
I am currently upgrading to a Haltech Pro and am getting rid of my current ECU setup. Apexi Power-FC L-Jetro (MAF version). It will come with the ECU, Handheld Controller, N62 MAF w/ pigtail, and Apexi Power Intake. Everything was working fine when the car ran last. Any questions, please contact me and i'll do my best to answer.
http://i198.photobucket.com/albums/a...pshvjuicfv.jpg
http://i198.photobucket.com/albums/a...psfpsmxb7s.jpg
http://i198.photobucket.com/albums/a...ps4zdlpmal.jpg
http://i198.photobucket.com/albums/a...ps7d7wugqt.jpg
http://i198.photobucket.com/albums/a...psychtr1sp.jpg
sickness14
ocation: Houston TX
Will ship at buyers expense
Contact by text or email
[email protected]
919-604-0494
Thanks!
R33 GTR RB26 power FC L-jetro with map sensor kit and EL commander for 1100 obo
ATI balancer for the R33 GTR RB26 motor 350 obo
RB25 Neo AWD stagea block, rb26 rods, Neo pistons, Neo crank (needs new keyway machined) N1 oil pump , oem water pump, RWD Pan and pickup modded $500
2 quart Accusump with elec solenoid $150
4" aluminum 90 degree intake pipe and 4" K&N filter $100
40mm synapse wastegate $150
3.5 to 3" downpipe for top mount rb25 , 200
outlaw7
Car: 78 zed
WTB RB26 coil cover if anyone has one lying around.
G-E
Car: 1. 1987 300zx Turbo-swap, SF interior, koni rallisport springs/struts, msa swaybars
2. 1997 Sebring coupe
3. 1987 300zx 2+2 becoming a caged racecar with RB swap...
Located in balmy Toronto
Contact by PM pls
RB25 NEO stuff is all very minty, only 28k kms, here's what's left:
a/c stuff, lines are good, compressor is clean, no bearing noise - $80 obo
almost perfect alt, the pulley hit the rad support on mockup so it has a slight dent, on the outer lip, fixable - $60 obo
oem turbo divided manifold, with heat shield, soot is from a loose turbo stud, no cracks - $offer
fresh engine mounts, no cracks in rubber - $40 obo
Largekid
Updated! ^
kevwa
Car: 95 Chevy S10 RB25DET
All parts are factory from RB25DET S1
Exhaust manifold -$40
Intake maniold - $40
Throttle body - $30
Fuel rail with stock injectors - $45
Turbo elbow - $15
Downpipe - $20
ECU - $100
Will ship all parts, buyer pays actual shipping cost
Best contact call/text 3157445589
chad b.
X-TuN wrote:Contact: [email protected] text: 352-325-1146 or PM me
RB26DETT Mitsubishi CAS (Cam Angle Sensor), not Hitachi
fits RB20/RB25(non-NEO)/RB26 $70 shipped
RB26 Exhaust Flanges (DIY Manifold) $45 Shipped
I need that CAS. I sent you a text.
Duke89
Car: 11/88 cream yellow/gray two tone RB20 project
WTB good OEM rb20det cams. Msg me or txt me with pics and price.
John - 931-334-1337
Greenblurr93
Contact: PM
Price: $1200 Shipped
Cleaning out some old parts and stumbled across this sweet looking box.
Opened it up to find a pleasant surprise, a brand new, AUTHENTIC Greddy Intake Manifold!
$1200 SHIPPED within the continental US
chad b.
Need an S1 (Mitsubishi made) RB25 CAS.
HMU
251-508-0914
RRRRB
Car: 98 RB powered S14
RB30 pistons and rods, everything in great shape piston skirts are flawless.
Complete set.
$200 Make an offer
whoareu
Car: 1993 rb25det s2 240sx vert
WTB - i need a pulley from an rb25 alternator... i have the quest alternator but its a 4v pulley and slips occasionally. and i read that the rb25 alt pulley will swap right on. if anyone knows of one or has one for sale it would be much appreciated. or any info as to any other pulleys that will swap right on. the noise when it slips is unbearable.
Abe23
Car: 98 240sx
I have a couple of Rb parts for sale accepting reasonable offers I'm willing to ship at buyers expense.
Abe B.
Contact: 305.546.9669
item: RB26 nistune
ship: yes
PRICE: $450
Rb26dett ecu with brand new Nistune board also has cable for laptop.
Item: Rb wasted spark setup
Ship: yes
Price: $125
Setup was used on a rb26 has grand national coil pack with Accel aftermarket wires.
Item: Rb26 igniter
Ship: yes
Price: $100
Removed from a running car in good condition.
Item: Rb25 starter
Ship: yes
Price: $80
Pulled out of a running car.
Item: Rb26 harness
Ship: yes
Price: $125
Harness was converted for a s13 but was never installed don't know if it works.
Item: Rb blitz filter
Ship: yes
Price: $60
Had this on my rb25 works great.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
WTB SHIFTER GUIDE BUSHING/PLASTIC WITH 2 GUIDE PINS.
PART NUMBER 32850
240z4u
Car: '95 Nissan 240SX
Plug and play LS coil swap for S2 RB25DET.
post4887481.html?hilit=LS%20coils%20another#p4887481
That setup is for sale. I'll include the coils (8 total), bracket, harness and a set of OEM LS plug wires which are too short for this application. You could likely use the special terminals and boots on universal wires. I'll include whatever I have around for plug wires as well. $150 shipped in the conus.
EMAIL or PM me, I don't come into this forum too often anymore.
Evan
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
We're overstocked with "oversize" ACL bearings for all RB20 RB25 RB26 and RB30.
If you need bearings hit us up with the motor and sizes you need. [email protected]
:mike
rb280z
Car: 1976 280z rb20det hx35 holset
Deatschwerks 650cc direct drop in injectors for rb20det. I put them on ebay http://www.ebay.com/itm/Deatschwerks-In ... cf&vxp=mtr
gnubberlang
Car: 1995 240SX SR20DET
2004 Frontier 4x4 Crew Cab 5-Speed
WTB RB20DET stock 270cc injectors
RRRRB
FIC 900cc injectors (same as ID1000's) great shape, comes with everything needed 10k miles pump gas ran thru them only
these cost 625 new
asking 460 shipped
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Need some motor brackets for an RB20. Hopefully some one here has an extra set.
KavVeMan
Car: 1991 240sx rb25det swap
still got those splitfires? and are they for an s1 rb25?
Nesquick
Car: Rb26 Kouki Silvia
FS:
12x RB26 Coil packs and Coil Pack Harness - $10 each, harness = $30
Stock R33 GTR Turbos - $100 each
2x J60/Z32 MAFs - $60/per (IN FANTASTIC CONDITION)
Shipping and PayPal Fees Extra.
Let me know
