RB Classifieds - RB engine Parts Only
Nesquick
Car: Rb26 Kouki Silvia
^^^^ Sorry, above MAF sensors are for RB20/25 (Green Label)
Snyda
Car: 91' Nissan 240sx
Wtb the following in good working order:
-Rb20 Ignitor
-Rb20/25 Stock Turbo manifold
-Rb20/25 Turbo
-Rb20 Good condition Crank pulley
-Rb20 Alternator
-Rb20 Starter
Largekid
Car: '96 RB S14 SE, '04 LS6 CTS-V
I have a RB25 Exhaust manifold. email me at largekid02 at yahoo if ya want it.
Funktown240
Car: 93' 240sx
Forgot I had this extra harness for RB25 to S13, its new. Retails for $125, I will let it go for $75 shipped.
http://www.wiringspecialties.com/wsprrbins1321.html
Text 817 681 6435
Still have this as well, price is OBO
Full face Kevlar clutch kit, will hold 450 ft/lbs. Only have 1500 miles on clutch, machined flywheel before installation with 500 mile beak in. Comes with flywheel, disc, pressure plate and alignment tool. Currently still in car but should have out by next weekend. Got a Nismo twin disc setup so I need to sell. $300 shipped
Stage 3 - Street/Strip Series 2300 Clutch Kit
This segmented Kevlar material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life.
Funktown240
Car: 93' 240sx
Thinking of selling my turbo setup that would be capable of 800+ WHP. Includes Doc racing single scroll T4 manifold, Precision 6765 turbo with twin scroll ceramic coated turbine housing (1.00 A/R), Tial 44mm MVR WG and a Sound Performance Quick Spool Valve to get the turbo going earlier in the powerband. Everything is new and has never seen oil or exhaust. Im would like to keep everything together but know this is unlikely. All prices would be very reasonable, anyone interested???
http://postimg.org/image/mmaw50sed/
http://postimg.org/image/s33h1gnyv/
http://postimg.org/image/6ttbgvfzj/
http://postimg.org/image/56im24iuv/
716RB
Car: RB25 Series 1 Swapped '89 240sx
Looking to sell my AEM S2 ECU for an RB25. Brand new in the box and never used. Looking to get $1400+Shipping. Trigger discs for both RB25 CAS and Z32 CAS will be included.
Booztd 3
Car: 1990 Nissan 300ZX TT
Looking for a good RB20 ECU
Prefer it to be socketed but not mandatory
Ben240sx
Car: '95 240sx
awd BNR32 GTR swap
Funktown240 wrote:Thinking of selling my turbo setup that would be capable of 800+ WHP. Includes Doc racing single scroll T4 manifold, Precision 6765 turbo with twin scroll ceramic coated turbine housing (1.00 A/R), Tial 44mm MVR WG and a Sound Performance Quick Spool Valve to get the turbo going earlier in the powerband. Everything is new and has never seen oil or exhaust. Im would like to keep everything together but know this is unlikely. All prices would be very reasonable, anyone interested???
sooooooo......what did you want for the whole package?
716RB
716RB wrote:Looking to sell my AEM S2 ECU for an RB25. Brand new in the box and never used. Looking to get $1400+Shipping. Trigger discs for both RB25 CAS and Z32 CAS will be included.
For $1400 I will include shipping, GM 3 Bar MAP Sensor w/ pigtail an a GM IAT Sensor w/ pigtail and weld-on Aluminum bung. I am located in Buffalo, NY for anyone who may be local.
Funktown240
Car: 93' 240sx
Ben240sx wrote:sooooooo......what did you want for the whole package?
Sorry dont get on here very often, I was thinking $2500 plus PP fees and shipping for the whole shabang. BUT this is on hold because of a potential local buyer. You can PM me your number and I will let you know if this changes.
716RB
Taking offers so I can move this. Trying to go a different route.
95_240
Car: 1995 240sx
Nismo type a fpr I pulled of my RB25 in favor of a top feed setup - $100 shipped
Ben240sx
Car: '95 240sx
awd BNR32 GTR swap
your pm's aren't enabled eeeeerrrrrr something. where are you located?
Funktown240
Car: 93' 240sx
Ben240sx wrote:your pm's aren't enabled eeeeerrrrrr something. where are you located?
Sorry, had no idea. I am located in Ft Worth, TX
julio
Car: RB26 AWD converted S14
PM or 860-501-34 six one is best for contact
South Bend Clutch - $250
I have a South Bend Clutch for sale out of my RB26. It fits NA 300ZX's & RB25/26's of course. It's rated at 530 lb-ft and is a great driving clutch. This clutch is barely used (less than 1,000 miles), is in perfect shape, and is ready for a new home. The only reason I am selling is because I went to a much larger setup for big power (700 lb-ft). As you can see from the pictures, the pressure plate surface has no heat spots and the disc has pretty much has 100% of it's life left. The pressure plate friction surface has been lubricated to prevent corrosion. They go for $460 brand new.
Clutch will come with a new throw out bearing (spring too), pilot bushing, and clutch alignment tool. See here for the specs on the clutch from the manufacturer: http://www.dxdracingclutches.com/ecomme ... em_id=2255
Precision 6266 Dual Ball Bearing CEA Turbo - $1300
New, never seen air, oil, or exhaust. Only bolted up for mock up. Its a dual ball bearing unit, has the billet/machined CEA compressor wheel, has the divided T4 $100 option with the 3 5/8" v-band discharge flange. Will come in the original packaging, oil feed plug/warning label, and the oil drain gasket. These run for $1700+ brand new with the DBB and divided housing option, so its already discounted $400 as it stands.
Compressor Housing: Ported S (4" intake, 2.5" discharge)
Turbine Housing: T4 Divided 1.0 A/R (3.5" v-band outlet
Condition: Brand new, never seen air/exhaust/oil, only bolted up.
RB25/26 Head Flange & Welding Plate - $150:
-Cost me $120
-1/2" thick stainless steel
-Has a universal RB bolt pattern so that it will fit an RB25 or Rb26
-Features recesses to make fabrication of runners easier/better
-Includes an oval (exhaust port) to round taper (runners)
-Meant for 1.5" Schedule pipe
Plate & hardware:
-Cost me $140 in materials & labor
-1" thick mild steel
-Has same bolt pattern as the flange so it will work for both the RB25 and RB26
-Worked great on my manifold, no warpage at all
And now for the pics...
rastaman
Car: 98 240sx
Snyda wrote:Wtb the following in good working order:
-Rb20 Ignitor
-Rb20/25 Turbo
-Rb20 Alternator
-Rb20 Starter
I have stock rb25 turbo maniflod. 109 shipped
maxuel86
Car: 1992 r32 GTR
I don't know if I should be posting this here but for some reason, I can't send Pm's. Im looking to buy a set of coilpacks for a gtr r32. If you guys have any for sale, please email me at [email protected]. Thanks.
outlaw7
Car: 78 zed
I've got a couple parts for sale off my rb25 s1:
Good condition factory oil pump 50 plus shipping
Set of valve covers 50 plus shipping
Green label maf 50 plus shipping
Stock throttle body no tps 25 plus shipping
I'm sure I've got some other stuff lying around
On a side note I also have an aeromotive fpr that's not being used anymore for 80 plus shipping
All items are obro
Pics up tonight
Thank you for looking
Jjonas828
Car: Stock (for now) 1991 300zx Turbo
My RB26 project
Located in Asheville, NC
Message me for specific prices. I will combine shipping and the more you buy the better the price ill give you. I am looking to sell all this stuff quickly. Message me with any offers. I will also sell entire engine with all parts ($3500obo)
I have a bunch of misc parts, so if you are looking for something specific let me know and ill see if i have it.
ACL Tri-Metal Race Bearings Main and Rod - 200.00 obo
ARP Main and Head Bolts - 350.00 boo
OEM Rods with ARP Bolts - 150.00 obo
Ross Tuffbond External Oil Pump Mount and Gilmer Gear - 450.00 obo
Ross Tuffbond Metal Jacket Harmonic Balancer - 500.00 obo
Raw Brokerage Oil Filter Stud - 5.00
Cometic Head Gasket - 100.00 obo
Cometic Exhaust Manifold Gasket - 25.00 obo
Stage 4.5 Clutch with Tweak Pressure Plate - 200.00 boo
Wiseco .20 Forged Pistons - 600.00 obo
Gilmer Oil Pump Drive Gear - 15.00
AFCO Double Pass Radiator - 200.00 obo
NASCAR Take Off Pressure Tank Set to 21 PSI - 75.00 obo
OEM Accessories (starter 50.00 obo, alternator 75.00 obo)
OEM Gasket Set - 75.00 obo
Mild Steel Turbo Single Manifold - 250.00 boo
All Original Fasteners and Hardware - 50.00 obo
Solid Steel Inserts for exhaust manifold Studs - 25.00 obo
RB26 Block Machined to .20, resurfaced, and the girdle was strapped. - 350.00 boo
Gutted Oil Pump to act as front seal. - 25.00 boo
OEM fuel Injection - 75.00 boo
OEM ECU - 75.00 obo
OEM Flywheel (Resurfaced) - 50.00 boo
Original Turbos(one blown, one may be good) - 200.00 boo
Painted Valve and Timing Covers with -12an fittings - 350.00obo
Machine Cylinder Head(Resurfaced, Pressure checked) - 300.00 obo
OEM Watercooled Oil Cooler - 25.00 obo
I don’t have the stuff in front of me so i think I have left some minor things out
IronMonkey
Hey guys, have a few parts to clean out my garage. Are parts to be picked up in Columbus Ga or will ship at your own expense. Text me at 706-442-2003 for quicker responses.
*(6) Sard 550 sidefeed injectors (high impedence), on stock Rb25 fuel rail, nismo fuel pressure regulator, and B&M gauge. This is a plug and play setup. I made 460 whp on one Z32 TT fuel pump. $550. Not looking to part out at the moment.
*Innovate Wideband, with sensor and wiring. Gauge has some small nicks. Got it in a trade, dont need it $120
*Tial 44mm wastegate in silver. $250
*Greddy Type R bov. This is the real deal. Great for high boost applications. Sounds amazing. Supra guys swears by them. Adjustable. $175
*Apexi 3" intake Price Reduced to $40
not my car...heres what the Greddy Type R bov supposed to sound like
https://www.youtube.com/watch?v=GHy8TweDnNo
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
RB20DET transmission for sale. Went to RB25 transmission, Located in Socal in the Inland Empire. $400 picked up.
chad b.
Car: chocolate chip kouki
Jjonas828 wrote:My RB26 project
OEM ECU - 75.00 obo
PM'ed
drock295
Car: S13.5 rb26dett
Hi wanting to buy rb26dett OEM intake itbs throttle plate and sensors will pay for shipping g va area. Email [email protected] thanks in advance.
noobie285
Car: 1993 nissan 240sx
1992 nissan 240sx
2006 scion xb 1989 240sx 2009 challenger
looking for rb20det silvertop valves. both intake and exhaust.
soates4
Car: 300zx
Joker85 wrote:some parts for sale located in Marrero Louisiana willing to ship at buyers expense all prices or obo so make a offer
used rb25 oil pan few dents not bad enough to block pick up $60
used rb25 oil pickup tube no dents in strainer and clean SOLD
used set of rb25 oem valve springs both intake and exaust $40
Still have the oil pan?
RRRRB
Car: 98 RB powered S14
Competition clutch Twin Disk clutch kit
This clutch has about 8k miles on it, and has seen mainly around 400-500whp all its life, Its in great shape still plenty left on the discs and has no issues, Splines are in great shape and discs have alot left on them
*new discs measure .250
*service limit is .220
Comes with everything including throwout bearing, its a push style clutch and should fit any RB engine using an RB25/RB26 push style trans.
Asking 750 shipped
Project Racebred
Car: 95 240sx with awd RB34DETT swap coming soon
WTB: RB25/26 bell housing.
Largekid
Andrew Benson
Indianapolis, IN
PM for number, email @ largekid 02 at yahoo
Price: $225 shipped.
This listing is for a BRAND NEW, never opened set of valve springs for a RB20DET. I needed a set for a RB25DET and messed up and ordered the wrong set. The restocking fee is 20% + shipping, trying to limit my losses. I opened the paperwork inside the box only to find out if any of my personal information was on the paper. You even get the smarties that was shipped with it! Below I have included the specs copied directly from Supertech's catalog about this part. They are for a hydraulic lifter RB20, and the kit has springs only in it. My loss is someone else's gain. If you have any questions, please ask. I will do my best to answer, but these are pretty self explanatory.
Specs:
Part Number: SPR-2081/RB20
Type: Single Spring
Press.Seat: [email protected]
Press.Open: [email protected]
Max Lift: 12.10mm
Coil Bind: 20.70mm
Rate: 9.60
Retainer: RET-NVG1015/T1 +SEAT SS-2820/2.2
OutSpr.OD: 27.50mm
OutSpr.ID: 20.00mm
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
Hans Scheibe
Email: [email protected]
Item: RB26 11mm Precision 1000cc top feed injectors (low Impedance) New installed once but no fuel ran through them, Decided to run bigger injectors for e85
Ship: Yes Free if shipped in the U.S.
Price $480 Paypal Accepted
JayNoel
Car: 90 RBZ32 rescue project
All Parts are OBO 60xxx miles est on everything
nissan rb25 45v4 turbo (down pipe elbow and intake elbow included)
stock rb25 intake
stock throttle body
stock exhaust manifold
oem used clutch
oem used flywheel
a/c pump
Oem motor brackets steel/alum. (i have both)
Oem motor mounts
Stock 370cc injectors
Oem fuel rail
Oem Pullys including the crank shaft pully
