The car is back on its wheels...I'll have to teak the suspension a little bit more before driving it to anywhere since the alignment is horribly off.
With the free time that I do get every now and then, I usually ended up working on the SR.
Just a list of the parts that I had ordered for it:
Koyo Aluminum Radiator
Nismo Thermostat
ISIS Radiator Hose Kit
OEM Water pump
Megan Racing Downpipe and Turbine Extension
Circuit Sports Turbo Lines
Agency Power Auto Manual Clutch Line
Greddy Oil Filter Relocation Kit
Circuit Sports 7 Layer Exhaust Manifold Gasket
OEM Valve Cover Gasket
Circuit Sports Thermal Intake Gasket
OEM Turbo Inlet and Outlet Gaskets
OEM Intake Collector Gasket
Gates OEM Heater Hose Conversion
Nismo Motor and transmission Mounts
ISIS M-Spec Intercooler Kit
HKS SSQV BOV
ER Spec Aluminum Driveshaft
Spec Stage 3 Clutch
ARP Flywheel Bolts
Fidanza Lightweight Flywheel
And a bunch of other little things....gauges, etc.
The hard fuel line that was cut.
Everything so far had gone well...up until now. As I was tightening down the Intake manifold, I managed to crack it (in all honesty, more like broke it)...Not only that, but I had the torque wrench set to only 15 ft lbs....wtf.....
Out of curiosity, I decided to tighten down another bolt on the manifold just to see what would happen....and sure enough....it cracked, again.
At this point, I'm going to have to hold off on working on it until I find a replacement manifold...
(^ how I feel right now...)
I really wanted to get this car on the road again this year...but it's looking like that might not happen, especially if any more setbacks likes this occur.
