DirtyGhettoKids wrote: Fiberglass can be used on things that aren't only fiberglass, I used this to shave my antennae on my coupe.
This is true too. I guess its just all about personal preference and for me, i avoid that stuff because i have only worked w/ fiberglass only once before and also if that stuff gets on your skin, its gonna itch like a motherf***** lol.
DirtyGhettoKids wrote:thats alot of time put into this car already
Bwahahaha, oh man, you have no idea...let me put it this way, this week alone, i have only gotten about 18 hours of sleep so far.
Bumnah wrote:What do you use to fill in the holes and sand smooth the holes in the front bumper?
I'll have to check on that too. There is a specific name for it...um, it was some type of fusor bumper mesh stuff first of all....well, i'll have to take pics of the back side of the front bumper to show ya what i did.
Bumnah wrote:I've done very limited body work, and I know polyurethane bumpers are a pain to work on.
Oh yeah, they are a pain to work on....you'll see why in the next update when i get to it later on tonight or tomorrow morning.
duffman1278 wrote:Had a question, did you apply the body filler before the primer or after? As in, the filler to the bare metal or onto the primer first?
You definitely put the body filler on the bare metal first; block it down til is smooth and flat, then spray primer over it...then block that down to knock out any noticeable sand scratches and to check to make sure there are no high or low spots, etc.
If you put the filler on top of the primer...you'll be setting yourself up for trouble later on down the road.
Ugh, loading the pics onto photobucket taking longer than i thought...
