I have have a 26-10-16 ET Drag mounted to a 16x9" wheel that we use on our second shop Supra. The lug pattern is the same. I have had these wheels on my 95 SE 5speed with no interferance. I was also running Volk GTP 17x10" wheels in the back with a 275 40-17 Nitto drag radial. The wheels just BARELY fit. I had to grind a bit on the lower A arm where they just rubbed the inside of the wheel lip and the lip also would just touch the shock body on full compression.Boost_Veteran wrote:I've actually been hoping to run some 10 inchers in the back but am having a hard time finding people that have actually done it w/o ALOT of modifications. Let me know how the 10s fit and what offset if possible, thanks. Car looks very promising
I have the 300z TT AT rear diff and axels at the shop. I am sure that these will be plenty strong for the weight of the car and the power I plan to put down. I am just not sure how I am going to get those to work in my car. The advantage of using an automatic trans is its MUCH less harsh on the drive train then a manual trans car. On the MKIV Supra, we have seen quite a few driveshaft and differential failures with the manual trans cars and only ONE failure of a diff on an automatic car. This failure was caused by launching on a trans brake. This Supra has our SP400 transmission in it.WDRacing wrote:What are you doing for axels?
According to the NHRA rule book, you need to replace the rear axels and diff with a straight axel setup. This rule is overlooked for the imports especially when your running in a class that requires you to run the stock IRS setup. Easy Street's sub 10sec WRX is competing in the NHRA, NDRA, IDRC, and BOTI Import races and gets thru tech every time. I talked to Ali about this about two weeks ago and basically he said they have to let it slide.WDRacing wrote:I don't think the stock axels are legal for a car running sub 10sec times...
Its a .96 A/R and yes we do use a 200hp spool up kit to get it up on line. On a KA with only 2.4L I am sure that it would need simular NOS setup to get it rolling. Its actually only an 81mm turbine wheel but still put 960whp down at base boost (31 psi) with a 2JZ 3.0L motor spinning the turbo.WDRacing wrote:Cool, I was worried about the axels, Custom crap gets expensive. I didn't know that about the IRS.
You'll need a dose of N20 to get that to spool up. Whats the EX AR?
No Kirk Racing.IvanAtSPRacing wrote:Is that the Autopower bar?
Are you looking for drag wheels or road wheels? Weld has nothing that will fit. The back spacing just isnt deep enough. I am getting really anxious to get the wheels from Bogart.....Boost_Veteran wrote:sweet. I've been looking around at alot of different rims with good weight and sizes but not much is comming up. I wanted to try to fit 10" wide rims in the rear but couldnt find many that werent in 17" which I think is getting into stunna territory. HRE sells some that are 16x10 and I think Weld makes some nice 15x9s in the aluma-star 2.0 and magnum.
As for the turbo, you said it was a T4 and and a GT series with a .96 A/R on the hotside. Any more info on it . . . GT42? GT3071? I dont think I've ever heard of anything from Garrett, Precision, or Innovative with 81mm wheel and .96 A/R . . . thanks
Modified by Boost_Veteran at 5:05 PM 10/6/2004
5Zigen FN01R weighs 15.1 lbs. in a 17x9.5 ... 17" ET Streets are made now, along with the DR's.Boost_Veteran wrote:sweet. I've been looking around at alot of different rims with good weight and sizes but not much is comming up. I wanted to try to fit 10" wide rims in the rear but couldnt find many that werent in 17" which I think is getting into stunna territory. HRE sells some that are 16x10 and I think Weld makes some nice 15x9s in the aluma-star 2.0 and magnum.
As for the turbo, you said it was a T4 and and a GT series with a .96 A/R on the hotside. Any more info on it . . . GT42? GT3071? I dont think I've ever heard of anything from Garrett, Precision, or Innovative with 81mm wheel and .96 A/R . . . thanksModified by Boost_Veteran at 5:05 PM 10/6/2004
I just ordered a set of CCW wheels 16x9 or 10 on rear with 16x4ish front with MT ET Street 26-10.5-16 rears and some sort of front runner for one of our Supra customers. The total price for this package was $2750 and $160 in shipping and included wheels, tires, mounting, ballancing, lugnuts, and center caps. These wheels are designed for drag racing and are still beefy enough to run every day on the street. The drawback is that the wheels are fairly heavy and arent exactly great looking.Nismo_Freak wrote:CCW isn't too expensive.
Tommy, not a problem. I am glad that I had the Cometic gasket in stock.racingdc9 wrote:Ivan,
car looks good so far. Thanks for getting the HG for us. Hope the HG helps.(crossing fingers) I'll keep you posted on how the car does. In the next few days.
Tommy
I will put a call in tomorrow to see what kind of time frame we are looking at.Boost_Veteran wrote:Let me know when you hear about the release of the GT40R. I've got friiends that are Precision distributors that also work closely with people from Garrett and none of them have mentioned anything about a 40R comming out .
I have 18x10 +40 with a 10mm spacer... The 10mm spacer lets me run my camber and keeps it off my rear shock...Boost_Veteran wrote:I've actually been hoping to run some 10 inchers in the back but am having a hard time finding people that have actually done it w/o ALOT of modifications. Let me know how the 10s fit and what offset if possible, thanks. Car looks very promising
I found this pic, so I guess they can somehow fit. I'll have my friend ask the Autologic guys later about the specs on themIvanAtSPRacing wrote:
Car sounds like it's gonna be great, Ivan. I can't wait to see the finished product. BTW, you know you're a car guy when you've got an exhaust AND a fuel cell in your living room.IvanAtSPRacing wrote:I have my Greddy Ti exhaust here in my living room next to my fuel cell.
Actually, the wheels/tires stick out about 1 inch too far. If you look closely at that pic. the fenders were rolled/flared as much as possible. They are actually ordering rear overfenders from JUN.Boost_Veteran wrote:
