yep... i cut the wood to fit right in the spot where the vents were... then used the bondo to give it better hold and make it smoothbracktheron720 wrote:Did you bondo straight to the vinyl?
it does crack a little.... but if you do it right and make your lines clean it'll turn out finebracktheron720 wrote:well im gettin it done!!thanks for the help Pezi!!the only thing i can think of is keeping the bondo off the vinyl as much as possible because the vinyl is soft and would allow the bondo to crack...
