make sure you get most of the fluid out and just leave enough in the box to lube it... otherwise it will too hard to turn the wheel to do you ant goodlil89ram50 wrote:hey pezi, jw how you did your power steering delete.... did you jus cut the steel hoses and crimp the ends?
So when your dial is set at 3.5psi it read's 3psi?PEZi720 wrote:it sticks around 3 mainly
OH... and the more i advance the timing the better... still no pinging as of yet either so i'll be advancing it more when the weather gets better and i continue tuning
yep... it drops to about 2.5 psi at full throttle at high rpm... there are 2 reasons for this.... 1 is that the fuel kinda bypasses the gauge as it goes to the carb (because of how its tied in) and 2 is that the FPR does limit the flow a bit... i've double checked everything and it all runs good so i'm leaving mine ondamn wrote:
Im trying to compare our trucks to see if im the only one with that wierd problem.
Doesnt the carb just love advanced timing!!
I was able to advance my timing until the distributor wouldnt go any farther but i starting pinging so i backed it off! Im going to buy a timing light to see where im at!PEZi720 wrote:well... the timing is really getting up there now... i think i'm almost to the extent of what i can run but have yet to experience any pinging
runs better every time i drive it... but the idle is still a little off.... don't care tho
