PEZi720... the build thread
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
PEZi
85NIS720 wrote:Oh, gotcha. Any tips on making one? I might have to try that out.
do you have welding tools? if not you'll need to take it to a performance shop
marleyone wrote:Hey pezi when you installed your weber did you run a line from the fitting on the upper passenger-side of the carb? I can't figure out if I need to run it somewhere or just cap it?
the one shown here with the red cap? if so its the float bowl vent so it technically should go to the carbon canister.... as you can see mine doesn't lol
85NIS720
Car: '85 Nissan 720
Yep, I've got welding tools and a pipe bender.
PEZi
well in that case making one is as simple as taking a stock cat... and then cut the pipe to be the same length... then carefully weld on matching flanges with the same angles so it all bolts up properly
85NIS720
Car: '85 Nissan 720
Sounds easy enough, thanks.
PEZi
new muffler on
also got turn down pipes and steel wool ready to go if its still too loud.... race tomorrow! go time!
codyshanetx
Car: 1983 DATSUN kingcab
what muffler did u go with?
marleyone
Car: 1984 2wd Nissan Pickup
[QUOTE=PEZi720]
Cool, thats just how have mine set up!
85NIS720
Car: '85 Nissan 720
Hey PEZi, how hard was it to get the Corbeau in and how much work did it take?
dogred
Car: 1983 D720
PEZi720 wrote:^ i don't think that thing is the actual computer... i ahve that thing too... can a larger actual computer on the other side... you'd honestly never know it was there until you pull the carpet
That is A.S.C.D. ,it has some lights that blink also.
Also depends on which year, I think the pre 84 models had the computer on the drivers side with the cruise control computer on the passenger.
PEZi
85NIS720 wrote:Hey PEZi, how hard was it to get the Corbeau in and how much work did it take?
corbeau makes a seat bracket for the 720... direct bolt in!
codyshanetx wrote:what muffler did u go with?
magnaflow XL turbo muffler
85NIS720
Car: '85 Nissan 720
Awesome, I'll have to look into that. Do you have any pictures of your 720 before flat black? I thought I saw one of your truck on a different thread painted.
PEZi
yep.... it used to look like this
1badsr20
love the truck and what youve done to itis the ka24e head a direct swap to a z24 if you keep the carbs
PEZi
1badsr20 wrote:love the truck and what youve done to itis the ka24e head a direct swap to a z24 if you keep the carbs
the head itself is a direct swap... but you'll need to make some decisions as to what you want to do with the intake manifold, exhaust, distributor (extra plugs).... and possibly the timing chain
PEZi
1984nissan720
Car: 1984 NISSAN 720 pick up/91benz300E
l
PEZi720 wrote:
lthose wheelz ookz f***en hot!!!
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Did you have to lift it back up to fit those awesome wheels? Are you leaving them white?
PEZi
same ride height... the tire is a little shorter
and yes they will stay white... with my awesome new pink race numbers
85NIS720
Car: '85 Nissan 720
What kind of shocks are you using after you lowered it?
PEZi
KYB's
i have the monomax in the front and and gas-a-just in the rear
Car: 1980 720 5-speed
I noticed the engine bay picture and mine ir revers almost like my air filter is on drivers side about the exhaust manifold. side of my block has on letter i cant see and then 20b and it throttle body
captainzeros
Car:
1981 Datsun 720 Longbed
1973 Datsun 240Z
That'd be the L20B engine, which has the intake manifold on the other side. The NAPS-Z engines are what you're comparing it to.
PEZi
^ yep
flinterman2000
PEZi720 wrote:same ride height... the tire is a little shorter
What's the tire and rim size?
PEZi
15x10 with -38 offset and 275/35/15 hoosier A6's
bracktheron720
Car: 1984 720 with 1980 datsun front end,1972 yamaha cs3
PEZi720 wrote:painted it
Hey pezi hows the new season treatin ya??what did you do to your dash ??i got that you painted it but its so smooth....any other steps that didnt get brought up??if you dont mind letting us in on your secrets!!i want mine nice and smooth but not a goofy fiberglass job i want it stockish..
PEZi
quite simple really.... 1. clean the hell out of the dash2. use fine grit paper (just enough to take the surface off of the dash but not enough to ruin the texture it has) 3. clean the hell out of the dash4. repeat steps 2 & 35. further clean the dash using M.E.K. (do this A LOT! you want to do it with a white rag so that you can tell how much of the color is coming out because this is your contaminants that will hurt the quality of your paint over time... the more you get out the better! the M.E.K. pulls all these contaminants out... the rag you are using will turn the color of the dash as these come out... the dash is clean when all the contaminants are out, but the kicker here is the rag will still keep turning color.... but you can kinda tell when its not pulling out as much anymore.6. clean with soap and water and let air dry7. paint.... using
bracktheron720
cool i was gunna use a product very much like that..how did you do the extra guages??it looks like thats where the air vent was...i wanna smooth everything BUT the vents any ideas??
PEZi
well if you look closely... i have the dash cut in half and there is no longer a lower portion to it.... the vents popped out as a result... and in their place i just used a little wood and bondo and made a little mount for the gauges where the vents were
bracktheron720
you da man pezi..
Return to “Datsun 720”
