rhart6 wrote:But this still does not explain why 400 and 500 HP engines don't seem to be concerned about these contaminants. Why?
Just trying to understand this insane service schedule.
That is because people who can afford these cars have more money than automotive sense. At least you are trying to understand the underlying engineering.
Once you do, you will see all OEM are only interested in getting your car beyond the initial warranty period when major repairs are on your dime, not theirs. They are in the business of selling cars, not proloning the life and performance of the ones currently owned beyond the initial warranty period. If you want to insure your car performs as close to new many miles down the road, you need to perform more aggressive maintenance. As an example, let me ask you how many times have you mechanically exchanged the ATF in your QX56? Have you installed an auxiliary ATF cooler for your 2.5 ton vehicle? Why not? Dont' think a transmission designed for a lighter vehicle requires it?
Read those last two sentences carefully and consider the implications. The most important is that OEM maintenance schedules are the minimum maintenance required to keep it rolling past the initial warranty.
Yeah, if I had any of the new AM, I would probably be changing the oil every 500 miles. I would probably park it in my living room at night, too.
