180sxfaktory wrote:That's why we have day before practice runs in order to "dial in" suspension and to see if the tires currently on the car will even help the car hook up at critical points on the course. datalogging is as simple as keeping a running diary of what was done at each track. You are right, the initial debut of the car will have nothing previously done as a benchmark. That's why we have communication and why we have pit crew.
In summary, have fun, but again, "I'm in it to win it" Dan and Sean!
I meant datalogging in terms of a Trakmate, DL1, or MaxQ setup or better. Something with a GPS/ Accelerometer that will allow you to objectively see where you can gain time. Otherwise, you're trusting the driver to be consistent enough to allow changes to the car to be noticeable in laptimes, as well as avoiding the "feels better in the corners" because you end up slightly slower going into and out of them.
For the most part, it breaks down to knowing the surface and condition of the pavement, rather than specifying track to track. I can pretty much guarantee you won't see as much variation from track to track as you will from different autocross (like Toledo, which has a directional grain to the concrete. Tons of traction in one direction, not so much in the other).
One other thing: Hoosier makes the A6 compound in a 275/35/R15 size. I'm not sure if the R6 is available in that size, though, but I know DJ McArdle from NY runs that on his CA powered S13. It might be worth looking into, especially if you never go beyond z32 brakes.
