SmithSR wrote:You should be caring about torque curves, because hp is a calculated number from an actual torque measurement.
The C5 has the torque advantage, and would have a much flatter torque curve, giving it greater force to move the mass of the vehicle sooner
.. if it can get proper traction.
Actually HP matters. Torque means nothing in the numbers sense. HP translates torque based on RPM to equalize for gearing advantages. The reason High RPM motors make so much HP is because it can use a lower gear ratio to achieve the same wheel speed but it would have more torque multiplication by the time it hits the wheels. Here's a write up I did many months back(Sorry if some of it doesn't make direct sense with this post. It was actually a response to something else, but you'll get my point):
"Torque peak on a stock KA occurs at 4400 RPM according to Nissan's rating. The highest redline I've seen on any KA is 6900 RPM. The peak torque is occurring way before that.
There could be a number of reasons to increase redline. If there is still power to be made, then it may extend your power band some. Keep in mind for a given amount of torque, the higher the RPM it is made in, the better. As an example, let’s consider an electric motor. They tend to make the same amount of torque all the way to its maximum RPM. You'll find that while torque is the same, HP will increase directly with RPM. So the more RPM you have, the more HP you have. Internal combustion engines do not have perfectly flat torque curves. Typically it rises to a peak and then starts diminishing. Even though it diminishes, due to the nature of Hp being greater with RPM (for a given amount of torque), the HP rating after the peak torque can still be higher than at peak HP. And in most motors, this is typical.
The reason that HP rises with RPM, is because it's a measure of potential. Frankly, HP is one of the most misleading terms when it comes to rotating engines. Torque is the force that actually accelerates your car. The higher the torque, the faster you will accelerate. So the best acceleration in each gear occurs at peak torque. But some smart guy thought up a device called a transmission. It has many gears that allow the motor to have more leverage. Lower gears allow you to put more torque to the wheels, and therefore you will accelerate faster. Notice your car accelerates its fastest in first gear? So why do we care about HP? Well, since the HP is a number that takes into account torque and acceleration it can tell us more about how well it uses the leverage your transmission provides. Typically, the longer you can stay in a lower gear, the more torque you can get to the wheels at any given time. All motors will get to a point where the speed is mechanically limited, or get to a point where the torque has diminished so much that shifting to the next gear would give you more torque to the ground. Ideally, you would want to shift at the point where the torque measurements at the wheels in each gear crosses the curve for the next gear.
HP is a calculated number. It is much easier to determine how fast a car will be from looking at this number than looking at just the peak torque number. If I were to say a motor had 150 lb-ft of peak torque, it would be hard to determine how fast the car is. It could end up being a motor that spins at 1 RPM but makes 150 lb-ft of torque with a 1 RPM redline. This would not be useful for nothing more than turning something that needed an exact output of 150 lb-ft of torque at 1 RPM. You could have 50 gears, and chances are you’d never get moving very fast at all. 150 lb-ft of torque at 1 RPM is .028 HP btw.
Now let’s consider I tell you that a motor makes 150 HP. It may make 150 HP even at 1 RPM. But at that one RPM, you would have 787,800 lb-ft of torque. Now, even with some seriously tall gears, I'm sure you could accelerate a car with some decency with that much torque.
For the sake of argument, let’s assume we have two motors that have a perfectly flat torque curve. Both make 150 HP. The first one has a redline of 100 RPM and the 2nd can rev to 1000 RPM. The 100 RPM would make 7878 lb-ft of torque. The 1000 RPM motor would make 787.8 lb-ft of torque. If we took the 1000 RPM motor and used a gear ratio of 10:1, you’d be making 7878 lb-ft of torque(ignoring any drivetrain losses), at 1/10 the speed of the motor. It would actually have the same torque and HP curve as the 100 RPM motor after the gearing. If the gearing were matched so that each motor hit redline at the same wheel speeds, they would accelerate the same. Even though the 1000 RPM motor made 10 times less torque, it can make the same HP because it can make use of the leverage additional RPM's give. And as you see it is quite linear. 10 times more RPM with 10 times more leverage with 10 times less torque achieved the same results."
