D-UNIT wrote: You see japan engines need all that tech, because of the car makers power limiting agreement.
RobDET wrote:VG30DETT running 15 flat??!! in an S13![]()
J-Spec Tuner wrote:there is some other thread with a turbo hayabusa, 525hp out of what, like 1 or 1.3 liters? Thats technology replacing displacement where displacement cannot be added.
tl1000sga wrote:Hell, I used to have a 'busa that was stroked and bored to 1466 cc, so displacement can deffinately be added to them. I don't know of any engine (factory) that couldn't benefit from added displacement, or technology for that matter.:freak
MrFox wrote:Actually you bring up a good point - All displacement is not created equal. Displacement resulting from added bore generally bumps both power and torque, whereas displacement from stroking will create greater torque, but will not significantly benefit power because of its impact on maximum engine speed.
This thread has generated too much good discussion to let die.
