s13sr20chris wrote:ok here i take issue. i think long stroke engines are tuned to be torquey because they are unable to rev high. just like a pushrod motor is tuned that way for the same reason.
C-Kwik wrote:That is exactly what I am saying is NOT the case. In any given gear, If you make 150 lb-ft of torque at all RPM's, it will accelerate at the same rate in that gear at all RPMs.
MrFox wrote:I think the problem is that each of us are using a different set of base assumptions, and we end up comparaing apples and oranges. Stroking a motor to me entails swapping in a crank with longer throws, which would increase displacement. Higher displacement = Greater torque. To hold displacement constant would require a change in bore, thus piston area.... the comparasion gets messy in a big hurry.
RobDET wrote:right... but acceleration is greater when torque is the same... that was my point... I'm speaking of the same motor in the same gear... the only variable in the S2k is RPM (torque changes but not mutch) Gearing is a factor but it doesn't have to be. If you ignore gearing the motor can still accelerate the car faster at 8K then it can at 5K even tho torque is pretty mutch the same... This is what you just said i think and what i ment by my previous post...
RobDET wrote:the vtec hit isn't what i'm talking about. When set up propertly vtec never does "hit" it feels like a smooth transition.
The motor is spinning faster it can do more work in a given time right? that means that one second of acceleration at 3k RPM does less work than one second of acceleration at 7k RMP.
Horsepower is afte all a measure of work that can be done.
RobDET wrote:oah and by the way i have felt a BIG increase in torque... I drive a turbo car...
RobDET wrote:horsepower = 550lbs., 1 ft. in 1 secacceleration can be measured in ft/sec/sec and weight is constant. Therefore as the numerical value of HP increases no matter what torque is the car will take less tim OR less distance to accelerate at the same amount.
GMC also prduced a 351 cu. inch V-6, and there was another over 400 cubes. The same platform produced a V12 702 cu. inch motor.D-UNIT wrote:Wow I thought GM only msde a 4.3 liter v6 engine. I never heard of a 5.0 v6 engine. That is awfully big. big block v6 big. Jeez even a stroked 4.3 only comes out to 4.6 liters. And with that 4.6 they were able to get 360 hp the wheels in an S-10. You had to have a 305ci v8 in your truck. With 151 hp from 1962 you must've had a single barrel carb and that special roll of quarters cam profile. Man that is hardly even comparable to a KA let alone a Q45. At least match or come close to engine years!!
