This is all a moot argument anyways. Who cares how you get there. 400 HP is 400 HP. 700 HP is 700 HP. Regardless of if it's from sheer size, high RPMs, forced induction, NOS, or even Fred Flinstone's feet, if you are making a lot of power, you are making a lot of power. Even if someone only goes and drops $45,000+ on some C5 or $70,000+ on a Viper, it will still smoke a lesser car. I'm certainly not impressed by large displacement motors that put out such low HP to displacement ratios, but they can still move a car very fast. You can't dispute getting your *** handed to you.
So is there replacement for displacement? Sure. It comes in many forms. All I care about is the HP. You want to compare a 400 HP turbo 240 to a 400 HP NA C5? Should be fun to watch what happens. And certainly, putting turbos on a C5 would give a very nice kick(Lingenfelter pumped out 725 HP out of their most powerful kit), but they are now replacing perhaps a 12.0L motor with 2 turbos.
As far as F1 cars, it's apples and oranges comparing it to a production based race car. 1st off they make tons of power because of their ability to rev very high. 18,000-20,000 RPM last time I heard. As far as all other aspects, consider F1 cars put so much downforce that theoretically, they can drive upside down provided there is enough traction to keep the car moving forward at that speed. You put that kind of force on the tires and the car will be all but glued to the road and can corner and brake faster than any production based race car. At the same time, I'm not sure that sustaining such high RPM's for 24 hours would keep the motor in one piece.
As far as the Rotary's 2.6L, yes, that seems to be the case given SCC's analysis of it in comparison to a conventional 4-stroke motor. However, once must consider that the newest version makes 250 HP with the same 2.6L with no turbo. Still behind the S2000 in displacement to HP if using the 2.6 figure, but respectable nonetheless. But 250 HP is still 10 more HP than 240 no matter which way you slice it. This pretty much works for all comparisons. Who cares about how you get there. Just get there.
