Pescakl1 »
https://forums.nicoclub.com/pescakl1-u98038.html
Wed Oct 14, 2009 2:33 am
First of all: Don't buy that kit, it is really bad quality, and if you want to move to more output, it is definitively not the way to do (BTW, you can find the same thing for way cheaper on Ebay).
The only way to get HID legal on a Rogue would be to change the headlight to the HID housings from the Rogue, and it is very expensive.Doesn't mean that you won't have glare, but it will be limited.
Now, the non legal solutions:
- Buy a HID PnP kit and install it in place of the halogen bulbs: You will have more glare but if you aim them lower, you should not have any problem.
- Buy the ugly kit you refer in your post which is supposed to be PnP. In fact, you will still have to open your headlight by heat (Oven or heatgun) to install it inside. From the work involved, it is better to move to the next solution.
- Retrofit your headlight to install a projector from another car in your housing. It involves some work as you have to find a way to fix it in the housing, hide the projector by installing shroud and bezel on it, aim it correctly (the hardest part), and close it to keep it waterproof. By using projectors from other cars (the best ones are those from Lexus, Infiniti and Acura), you will get the best output possible, and if you work them a bit (change the lens to a clear one, change the shield to a homemade curved one), you will get the best output out there. This solution is quite expensive (about 300-400$ of parts, plus about 200-300$ in labour if you make it done) and quite time consuming if you do it yourself, but it is the best one.Leo did it with Q45 projectors (impressive work and unique look) and he is working on another one I think. I am working on my own, with either FX35 or G37 projectors.
All the above solutions are not legal (even the kit you listed) but policemen have other things to do (did you see how cars have PnP HID kits now?) and we will give you a ticket only if they arrest you for something else (and only if they care).
My opinion is to do like everybody else is doing, buy a PnP HID kit and call it a day if you want to move to HID.
If you want to move in the retrofit world... then welcome and I have an extra pair of projectors and ballasts than I can sell to you I hope to soon show you what I have done so far to retrofit the Rogue headlights.
