This weekend I removed my old 5Zigen exhaust in favor of a BRM 2.5" stainless. This is mainly due to looks, and hopefully a better sound. The old exhaust was also a 2.5", so I shouldn't see any difference there. This is a street vehicle, so I included a high-flow catalytic converter. I've never been a supporter of going without a cat, as most evidence shows that there is little if any performance difference between high-flows and test pipes. Yes, they add expense, but its really not a bank breaker.
Yes, when the car was repainted, they did not completely mask the exhaust...
The BRM does not have this large canister resonator, so there is no hanger on the new exhaust either. This would not normally be a problem, except the last person to work on my exhaust did this:
That's the "exhaust bracket tube" that has been welded to the old catalytic converter. When the old exhaust was originally installed, it was jerry-rigged to go from the stock tubing to the larger cat and exhaust- they actually cut off the flanges and just welded things together; which was fine until I upgraded to the OBX header. Then, because I wanted the ability to bolt on and off, I had a mechanic weld a flange back on. Well this was the result. So I just ordered a new bracket for $40 shipped from Courtesy NIssan. Hopefully, this will take care of that problem.
I had fitment problems with this OBX crap, and even after I had worked to correct the problem it was still a b*tch to get out. But out it came- so long mediocrity!
Next I bolted up part of the BRM just to get it on and see how it will look- much better:
On to the header. After paying some money to Burns Stainless for their proprietary header design program recommendations, I contacted a company that does custom headers through a mock up kit:
Stainless Headers Mfg: http://www.stainlessheaders.com/index.aspx
They have some neat ideas, and looked like they could handle my project. Expensive? Yes, in comparison to OBX, but with the money I've spent on my engine, it made sense with my goals to spend the cash on a custom design. Plus, I get to look all cool in creating a thread like this, right?
So bolt up the flange (I supplied a gasket ordered through AMS for them to develop- anyone else deciding to build a custom header for the KA through Stainless can thank me for that)...
... and promptly forget to take more pictures with the aluminum elbows attached.
I need to purchase some 1.5" PVC tubing and wait on the "exhaust bracket tube" to finish mocking, but I figured this was a good start to document.
