When I had a KA, I made 145 whp/155 ft lbs on a Mustang dyno with intake, header, exhaust on a stock S14 KA. When you factor in the 12% conversion to Dynojet that would be about 162whp and 173 ft lbs.lexcrob wrote:Lemme try to end this bench race here before we go callin rotary engines reliable![]()
First off import tuner's cat back exhuast S14 only made 121hp....
The latest S14 had AEM short ram/cat back exhaust and the coveted 248 cam mod making a whooping 140hp...
I would LOVE to see a bone stock 240sx put on some rollers that would be EPIC -->150 is a joke right.
Ill have to admit 4psi yes very dumb needless to say i had some issues there. The good news is i learned exactly what NOT to do and it was crude to say the least.
help-t25-turbo-clocking-t530731.html
Id take pics of a couple time slips i got but eh you figure it out. Heres something to think about HR z huh.... 305hp to the crank 3600 pound car little research----
this is from nico actually!!!!
I would be interested to see the standard de and hr done at the same time and place, get a real reading of the improvement, and keep in mind all dyno's should be the same but they are not! I've seen stock 350's turn 240whp on a dynapack only to pull 225whp on a mustang dyno, and gine the sae ratings formula change I'd expect the hr's to be in the 260-280 whp range
hmm punch some of those numbers up on here guy http://www.hotrodpitstop.com/tool.php#1
I believe Zenki is correct here. With the aid of google95zenki man wrote:Try again. 08 hr Z with full nismo cat back, berk highflow cats, nismo headers, aem intakes, and apexi filters. Along with a few other odds and ends. I would cry if that car only put down 305 to the wheels...
Nice find i was keeping up with his build over on my350z and he helped me when i was buying a few things for my z. people are really all up on his nuts in love with that car for some reason. Iirc he is running some 19x10.5 in the rear so im sure theres a few hp being waisted right there but never the less some impressive numbers being put down.badbob2121 wrote:I believe Zenki is correct here. With the aid of google95zenki man wrote:Try again. 08 hr Z with full nismo cat back, berk highflow cats, nismo headers, aem intakes, and apexi filters. Along with a few other odds and ends. I would cry if that car only put down 305 to the wheels..., I found a dyno chart from an HR Z33 with similar bolts ons, but with a technosquare reflash.
http://g35driver.com/forums/tuner-dyno/ ... -350z.html
12% is a fairly agreed upon general conversion.lexcrob wrote:Im well aware of dyno differences and that they serve as benchmarks not percision measurements. The reason i reference import tuner is that they tend to use the same type dyno and their weather conditions *cali are also the same.
I really dont think their is a conversion for mustang vs dynojet 12% i suppose that could be correct. If it is id say your got a keeper of an engine only thing i can think of is altitude and temp. where big factors? Reguardless this wont ever end lets wait and see what that little 200hp can run down the strip.
As long as hes got some beef back there to hook up really nice im gonna say 9.0 flat will be a best time 9.3 average.
