Thanks for some extra insight on this. I ended up finding out that when I had the fans set up through the toggle switch, it was not getting 12 volts. And thus not running at full speed. I have since replaced this setup with the stock clutch fan until i can get together the proper items to complete it correctly. I'll keep your info on hand though when that time comes.NolimitZ32 wrote: ↑Wed Nov 15, 2017 6:34 amYou need to put it on a thermo-couple with adjustable controller so you can zero in on the correct temp, running the fan all the time (as in running your car too cold) has drawbacks, the engine is designed to run at optimal temps that why engines have thermostats. Secondary you probably will need to find a switched power source but that so you don't have to pop your hood every time you get out to shut it off. The fuel injector control circuit (on of the big white wires on the underhood side of the fender, you'll have to check the wiring diagrams) and the fuel pump are both ignition switched. There are others but I don;t know them off the top of my head.
Replying to both of your comments. Yes, I have done all of that. I removed the connector, following the guide. Set the idle to ~750. Plugged it back in. I could hear the idle jump up slightly and settle back down as it's supposed to. Worth noting, it does do this on every cold start. Maybe 3/5 times.
Hey thanks for reminding me. I've checked there for a lot of other info. I'll have to take a look at the info in there for vacuum leaks. I found a rubber cap that fits over the air intake. I just need to figure out a way to mcguyver it to work and try my luck with it.Ace2cool wrote: ↑Fri Dec 01, 2017 4:45 pmHesitation can definitely be vacuum related. Look at ffrpwner's "everything you need to know" thread in Z32 general and look at the device used to check for vacuum leaks about halfway down the post. Super helpful tool if you have a compressor. Turns a vacuum leak hunt from a wild goose chase to a pinpoint endeavor. Even couplings that seem to be right could have a crack or something, with as old and brittle as this rubber is getting.
Yea, ive been taking a look at the OSM and looking through old threads regarding EGR deletes. The one I found that mentioned doing it without removing the engine I think just said it was a PITA. I've also found some great youtube videos from TwinTurboTim (i think thats his name) and even he had the car up in the air doing the EGR delete.DCaff300ZX wrote: ↑Wed Dec 06, 2017 1:22 pmAs for EGR, I'd search the EGR delete threads ( I seem to remember some done without engine removal?) and use that info for my work, also the OSM is a friend with diagrams and the actual procedure in order to help you with what needs to happen. Never been there myself luckily as mine is still functioning correctly and not leaking, but was also serviced and upgraded harness applied (one failure area).
If going delete, be sure that your local emissions won't give you a real headache come tabs time as you probably won't pass without the EGR in many states.
Yea that's the consensus I seem to be finding myself. I would just cap everything off, but where the bolts thread into the plenum on the passenger and driver side rear are stripped. Which is where it seems my only option now is to remove the system entirely. Now, I haven't started calling around yet, but Arkansas is not an emissions state. So i might get lucky and find a shop that can just rip it all out and weld those ports closed. It's a bit trivial at this point though, I think.Ace2cool wrote: ↑Thu Dec 07, 2017 4:40 amIt's borderline impossible, but it can be done. Once you get the bolts threaded out as far as they will go, they will hit the firewall and still not be free. Those b***hes are ridiculously long for no apparent reason. If you really are determined, you can get a hacksaw back there and cut the bolt heads off and possibly slide the EGR unit off the backs of the bolts and then turn the bolts out with long pliers. Again, this is borderline impossible but it has been done before. Or keep turning the bolts out with pliers and remove them and the EGR unit at the same time.
What I did with mine was cut the tubes at the back side of the plenum, fill the tips of the tube with high temp RTV, and then bend them over with duck bill pliers until I pulled my engine, and then removed it properly once the engine was out.
Oh i see, good info. Reassuring that I won't have to replace anything in that regard.NolimitZ32 wrote: ↑Wed Dec 20, 2017 8:25 amAutomatics don't have a flywheel, they have a flex plate, the mounting holes size, thread, spacing on the crank are the same so if you're getting an engine out of an auto to put into an NA or vice versa you'll be fine, just reuse the flywheel/flexplate from your car.
As for the EGR bung, I did the research years ago, the oil drain plug for a mid 2000s diesel truck fits perfectly, I don't remember which one ford, dodge, or chevy, I want to say 7.3 powerstroke but not sure. That should get you closer.
If I don't have to worry about aligning things with the auto, then I may forgo trying to pull the trans along with the engine. That'll cut out some worktime for sure. My only concern from there, though, is removing all of the trans bolts?
That's where I'm at as well. Nothing but hand tools so far. Don't have access to power tools yet, besides a dremel.Ace2cool wrote: ↑Fri Dec 22, 2017 11:26 amBunch of extensions and 2 universal joints for the top left, bunch of extensions and one universal joint for the top right.
That's on a Supra, but it's the best image that shows what's going on. Just wedge something on in there and turn the bolts. However, IF we determine your engine is legitimately locked up, you won't really need to do that. For reinstall maybe. But right now you need to be tracking down possible hydrolock before we have any more talk about pulling engines.
FWIW, I've done my entire build thus far without the use of power tools. Hand tools only.
None at all? Really? Huh. Should have big holes in it. Like this: https://www.z1motorsports.com/piston-cr ... -6786.html
The donor engine is out of an Na Manual. So the flywheel/flexplate looks like a solid piece. https://www.summitracing.com/parts/atp- ... tPEALw_wcB Similar to that.Ace2cool wrote: ↑Fri Dec 22, 2017 11:45 amNone at all? Really? Huh. Should have big holes in it. Like this: https://www.z1motorsports.com/piston-cr ... -6786.html
I guess you could try wedging a flat prybar in the teeth of the ring gear? That's really odd. Or just try the impact method and use a box wrench and a ball peen hammer.
