Hi Greg, everyone. I figured I'd post some pic's of my install while I'm here... 2.5" aluminum, dual exit tips, 22" resonator. I intended to paint it tonight and install it tomorrow, but I was too eager.
Anyways, pretty basic stuff here: I roughed up the surface of the piping with a green 3M pad, wiped it clean, and let it dry in the sun. I was glad to see that the welds were already primered, which said a lot for the quality to me, even though it was the aluminum version. I sprayed it w/Rustoleum BBQ Grill paint, because it was $3 cheaper than the auto-part store paint! Good for 1200* too. Anyways, it turned out great, and I really laid the paint on. Almost 1.5 cans worth. It dried in less than an hour.
Ripped the stock exhaust off, then fired it up for sheits 'n grins.
Install was straight-forward, although pay attention to how the mid-pipe goes on! I'll spare myself the embarassement of elaborating.
Bolted right up, and the dual tips had zero interferance problems with my tow hook. Below are some pic's; wish I had taken more. The *only* problem I have is that it seems to hang low. It's almost 3-4" away from the rear sway bar in the rear(w/the car up in the air). FWIW I installed a zeifer test pipe, which may have something to do with it. I could never get my hanger on the transmission mount to line up, even on the stock exhaust. *shrug*, my guess is my header(stock)/collector is out of whack, the test pipe, or sagging stock rubber hangers.
Sounds great, and it really livened up my ride! Under 3k it's very deep and rumbly, at 3k it sounds pretty damn mean. Above 3.5k(on a stock DE), it really quiets down. I will certainly have to be carefull on main cruise streets on after hours/weekends.
All-in-all, love it. My only regret is not breaking down sooner to buy it.
Cheers,Jamie
You can see larger versions at:
http://jamie.hackthebox.org/files/)
::edit:: ...stupid URL's... ::edit::
