That is the dyno of my car back when it was stock with s13 cams. After I got a new tune for Scott it was 291hp and 295tq at 12psi. Turbo really seems to come alive around 13-14psi.GlacierFreeze wrote:Just takes a little looking around. Anyways, here's a link to a thread, which I posted in, a link to a dyno chart with a GT32. First page, half way down.
zerothread/202436
I'm getting about 15 psi by about 3200 or so when it was running . I was getting about the same with a stock engine and s13 cams.s13lawnornament wrote:sorry, I don't mean to get off topic here but I have been thinking about running a gt32 and was wandering what kind of spool up you were getting? Also sorry to here about your troubles.
I talked to my engine person and also Chris at AMS and they both have not seen or heard of anything like the stuff that is on my drain plug. That is what is so strange about this. Also, I have the first turbo that I blew up and the shaft to be okay.s13lawnornament wrote:Thanks for the link and info about the gt32 turbo it sounds like the one for me. As for your turbo faluire it might be the turbo if the bushings are mangeneise bronze and it had a burr or sharp edge on it that bronze will chew up a steel shaft in a hurry.That is the same material they make high performance valve guides out of and it is an excelent bearing material and lasts avery long time,but it is also very hardand a sharp edge will always cause a major issue. so, maybe if this happened with the first turbo and there were still shavings in the motor it cased your second turbo failure. I would say talk to your motor guy show him the pics of the drain plug and inside of the filter and see what his ideas are.
That sounds like water in the oil.s14det wrote:
Well I took the oil pan out and did not find anything. I took the Valve cover of and used a magnet and probed the head and did not pick up anything. I did take the oil filter off and poured out the remaining oil and it had a milk shake look to it.
Modified by s14det at 3:45 AM 11/5/2006
Well It looked more like small metal flakes. Like paint with really small flakes in it.Edub1 wrote:
I checked the compression about 1-2 weeks ago and was 150-159 on all cycl.Chezedik wrote:Have you checked compression?
Not sure what you mean? SorryYeajimi wrote:Whats the wet compression like?
How about no....GlacierFreeze wrote:Wonder if that mystery crud on the magnetic drain plug could be additives from the oil????
The oil pan was welded up when I first installed the turbo setup on the stock engine.Florida240sx wrote:It has to be bearings...or it was the machine work never cleaned off the block/head....How is your oil pan tapped?? Wndering if you may of hti the lining inside and a piece flaked off and then it constantly gets chewed away by the timing chain??
