WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Wed Oct 11, 2006 6:47 am
I've only driven a very few times myself...like 3...lol. I did it in my Miata back in the day, NA so it was a whole different animal. I guess there could be some turns where you dip close to 3000, but 3000 is really low in first. I do know guys prefer to stay in second, maybe thats why they dip close to the no boost threshold. In which case a smaaler turbo will be slightly more competitive. WHen I was in jail, I actually read Maximum Boost for the first time. Corky beel compares two cars from the factory, one uses a very small turbo and a sidemount IC because it has to or the motor will detonatevery badly do to the high heat levels of forced air. I believe it was a Nissan actually he used as an example of a turbo being to small. The other company was Porsche. Thye had no room for a IC at all, so they used what Corky refers to as a properly sized turbo, which was significantly larger then the Nissan unit, but could be run with no IC at all. The public didn't like the wait for boost...cause we are generally greedy and ignorant at the same time. But Porsche builds cars that are engineered to compete in races of all classes, aside from drag. When was the last time you didn't see Porsche in the top 5 of whatever autocross/road race event?
Alot of high HP cars will be racing together, I guarantee they don't all have boost coming out of the tight twisties, but it's a split second away. Those who run a large amount of boost pull away from the pack at the first sign of a fairly straight or long sweeping turn. Those who run low boost and a small turbo...well, they don't.
Sorry for the long reply. I'd say any turbo with a T3 exhaust flange will be better for racing then the T25.
Think about the cost comparison as well. What are your goals as far as money is concerned?
WD
