Chezedik wrote:Uhm, the fact that there are shavings on that plug is an issue, and he needs to fix it for you. As far as shavings in the case. Check your pump. But based on pressure, and the fact that it is running, I can tell you that is not where your issue is. It is because of the builder, plain and simple.
That might be true but he needs to pin down the cause before he can assign blame. It is normal to have metal shaving after rebuilding a motor. That is why you do extra oil changes. In his case, the shavings might have just permanantly stuck to the magnet from the begining and might just be innocent bystanders.
But why guess. Put about 8oz in a pop bottle with 8oz water, shake it up and let it sit over night. The metal, if it is metal, will be on the bottm. The oil will form a layer on top of the water. Pour all this out and you will have pure clean metal shavings if that is what caused the problem. And, I would get the oil from the turbo feed so you are not anylizing the sump oil.
One would think that a bad build with grinding metal would be quite obvious. I wonder if his turbo filter + flow restrictor could be causing too much oil resistance. For that matter, how can metal flakes get by that filter?
