I got the clutch to be bled somewhat. A few weekends ago i was at Autozone 6 times in 2 days getting parts to fix it. Ended up replacing the Master Cylinder and thats what did the trick, although i only bled it enough to drive the car home from a buddy's place where the hoist is. Dont know what i will be doing. This engine i have now is worse then the other one. Likes to die down. The other motor though is at a buddy's just a bit away. Has a 5speed motor and everything, clutch is decent, um...just runs rich dont know why. Let me know what you have in mind, my cell is always on and i can only check email certain times.scs13 wrote:pat, whats up with your clutch? you just cant get it to bleed right? bleeding it is always a pain in the ***. it works better if instead of pumping it you just push it to the floor one time and bleed it. it keeps the big air bubbles from turning into little ones when you pump it. if that doesnt work you might wanna replace the master and slave cyl, but its like 30 dollars for both.
anyways, what are you gonna do with your old motor?
DAMNIT! i just bought another FC today if i get this it'll be my third one and thats pushing the pocket book alittle. PLEASE SAVE THIS FC!!!!!!!!!! infactr if you do get it i will do my best to get you the parts youneed for it dirt cheap.Zee wrote:Someone pick this up PLEASE before he crushes it. All it need is the driver's seat, Passenger Headlight Assembly, and Passenger Fender. He wants $500 for it save this car Please!
http://greenville.craigslist.o....html
I was thinking about doing it pretty bad, but what I wonder is if he is selling it for this cheap is the frame bent? Makes me think it is. I will see if he still has it tomorrow which he probably will and I will see if he will take like $200 for it. Then could you get me a fender and a full headlight assembly for really cheap? I would much appreciate it. We will see how things go.SouthSideSlider wrote: DAMNIT! i just bought another FC today if i get this it'll be my third one and thats pushing the pocket book alittle. PLEASE SAVE THIS FC!!!!!!!!!! infactr if you do get it i will do my best to get you the parts youneed for it dirt cheap.
for me its a nice little car im trying to get the car but if i cant get the whjole thing i know im smaging those tails if you want you could have my S4 tails if you get the car.Zee wrote:Southside I have another question for you how is your FC for a daily driver? I ask because this would replace my daily driver.
urg so if the guy decides he doesn't want the whole car i would buy and iand i told him call me before you crush it!!!!Zee wrote:Well I am not going to get it because gnvarnadore contacted him also and he was told that he did not have a title to the car so I am not going to get it without a title. Southside you should contact him though because you could probably get those tails off of him cheap because he is just going to crush the car tomorrow. You might want to contact him because you could loose out on a great deal if you don't.
