You can always count on Gr8bryt to say something to chear you upgr8bryt wrote: Congratulations James, that is WONDERFUL!! At least someone's got some good news. I'm sure everything will work out fine with his lungs, just have faith.
I'm still without my car guys, only now I believe the problem is getting worse. I got it to crank yesterday and tried to drive it around a little. I made to my mom's house and back (less than 1 mile roundtrip), but it was kinda iffy for the most part. It was weird cause I had the gas all the way to the floor and it wouldn't rev past 2K. Now it just dies when I try to move from a stop as if it's flooding out or something. It's just sitting for the time being and whenever I do it to crank, it dies shortly thereafter. I just hope I don't burn up another starter before I get this issue resolved cause that would really suck!! Hopr eveyone else is doing well and I'll get at y'all later.
+1 for the maf. hit the junk yard and grab another one from a SOHC along w/ a good pigtail.maxima278 wrote:
a maf that is not hooked up correctly will most certainly do that to you, and you were saying your maf plug was messed up, right? Get that issue resolved even if you have to rig it temporarily, and I'll bet you will at least see improvement. If that doesn't solve all issues then you have a leak in your air system somewhere (except I don't think that is as big of an issue on non-turbo cars, but I don't know). All I know is my SR would not run right at all until I resolved those 2 issues. I thought there was more to it than that but that is all it was.
Hey Bryton, I happened to run accross your post while searching. When I had that car I had all kinds of problems with the o-rings on the injectors going bad and leaking. I tried to get remanufactured injectors, but they didn't work very good so I ended up getting some aftermarket Venom injectors. Here is the link for exactly what I put on there COXIMPORT. Once I installed these, I never had any more problems with leaking, and I didn't notice the car running significantly richer. I figured the intake would balance out the high flow injectors.gr8bryt wrote: I'm still without my car guys, only now I believe the problem is getting worse. I got it to crank yesterday and tried to drive it around a little. I made to my mom's house and back (less than 1 mile roundtrip), but it was kinda iffy for the most part. It was weird cause I had the gas all the way to the floor and it wouldn't rev past 2K. Now it just dies when I try to move from a stop as if it's flooding out or something. It's just sitting for the time being and whenever I do it to crank, it dies shortly thereafter. I just hope I don't burn up another starter before I get this issue resolved cause that would really suck!! Hopr eveyone else is doing well and I'll get at y'all later.
I try to stay upbeat, there's too much drama going on in the world as is. I know that life could be A LOT worse, I could be living in Iraqmaxima278 wrote:
You can always count on Gr8bryt to say something to chear you up.
FSUDrifter, I may be emailing you soon about that extra MAF since it will be a lot easier to get it from you than taking a chance @ the junk yard and possibly getting a bad one. I combined the various wires that go into the pigtail into just three and then reconnected them into their respective "ports" on the connect. Maybe I'll be able to snap a few pics to give you all an idea of what I'm working with. Oh yeah, I also need a new valve cover gasket, but that will come later since it's not leaking oil too bad right now.FSUDrifter wrote: I would try to take the plugs or connectors apart and clean them up and maybe re-solder them (not too sure exactly what you think the problem is). I have another SOHC MAF and a redtop MAF sitting in my garage if you find out your MAF is bad.
LOL, I'm sorry Chris I can't heip myself, but that is pretty darn funny.kaChris803 wrote:wuzzup ya'll. well after a little miss hap, i'm free!! long story short, i lost my tag on the back of my car, reported it stolen, found it, called back and said i found it, went out, got pulled, GOT ARRESTED!!, got set free with no bond, and got an apologie!! really, is that all i get!
The guy that was gonna trade the s14 wasn't old enough to make a decision like that and his dad stepped in and told the kid no. So now he's got a turboed fc that runs and rides pretty well.maxima278 wrote:I thought you traded for an S14?
my dad listened to it run this morning and he said "duh it's been sitting for like 2 years with almost no gas in it there's probably at least an inch or 2 of water in the bottom of the tank.Redemption1978 wrote:I think the knocking sound is a valve but you probably have a fuel issue as well. Just what I think when I heard it.
maxima278 wrote:btw Happy Thanksgiving everyone.
