NC SC CHAT
Including AR, LA, MS, AL, FL, GA, SC, and NC
gr8bryt
Car: 2003 Infiniti G35 Coupe 6-MT
1994 Toyota Camry V6 (Sold)
90 240SX SE Hatchback (Sold)
90 240SX SE (R.I.P--12/24/2007)
ClubSX wrote:and I have so many $1 bills in my drawer (because im a server) it looks like i robbed a gang of stripper's. I have decided that if i can find a low mileage KA that i will be going KA-T. That way i can get the parts that I want to get and also time by time. Also swap in the 5speed at that time also.
That plan sounds good, just do your research so that it stays reliable.
gr8bryt
zerothread?id=180502
Here's the link about that zenki, I went ahead and put it in the classified forum.
Black on Gold
Yea, i think KA-T is the best way to go. Get the torque, prolly spend 1/2 the money. The only thing i need some help on is what i should replace on the stock KA to be able to handle the Turbo.
gr8bryt
That's where the other 1/2 of the money that u save comes in lol. You'll wanna get a thicker head gasket (a metal one would be good), injectors, lower compression pistons, forged rods, strengthend valve train, head studs, fuel pump, and of course all the stuff for the turbo itself. It probably wouldn't hurt to get an oil cooler while you're at it. IDK if that's everything but that should get you started in a positive direction.
maxima278
Car: 96 240SX SR20, 69 Ford Pickup, 99 Dodge Ram 1500, 1996 Nissan Maxima, 1997 Nissan Maxima project, 89 Coupe shell
I actually abandoned the idea of the KA-T because it just looked like a really expensive endeavor once you add up everything you need to make it handle the turbo, plus the cost of the turbo itself, when the SR is already turbo-ready plus it has a turbo! I may be wrong but I just don't think you can get the kind of horsepower out of a ka-t reliably that you can get with an SR.
On the other hand, the tophat motor is essentially a NEW motor, which is nice, and you can't get a new SR, so that's one thing it has going for it. I guess you're going to spend money either way, so at least this way you can spend it more gradually.
The only thing that I think would make this an economical choice would be to do no modification to the motor, do a junkyard turbo swap and turn the boost low enough to not blow the motor.
but I will have one for sale if you want it.
Black on Gold
See the reason i think its alot easier is i dont know what all i need to do to get the SR ready and put in. i.e Harness, what drive shaft to use (ka?). Maybe you can help me with it all James. That would be really cool. Anyways im working 3rd shift tonight 11pm-7am so i'll talk to you guys later.
maxima278
driveshaft is the same, engine mounts are the same, only thing different is wiring. But I will definitely be able to tell you everything you need to know once my car is running with the SR in it. I like it because it was designed from the start for boost. With the ka, you have to design it to work, and I think that's scary to me considering how little I already know about turbocharging. have fun at work man.
gr8bryt
ka-t vs. sr will always be an ongoing debate imo. Everyone has their reasons for going either way and therefore there is no right or wrong choice. In the end, it comes down to personal preference and just how far you're willing to go. ClubSx, what are your long term goals for this project? IF you just want a boosted 240 to drive around, I'm sure the ka-t would suffice with a few mods and 10-12 psi. If you want a car primarily for the track, then maybe the sr would be more cost effective in the long run. The reason I say that is because unless you have some inside connects @ Nissan, there's really no way to put a motor together for boost the way that the manufacturer does. It would really suck to put $1000+ into a motor and then blow it up because of high boost. It's true that it can happen to any motor with improper tuning, but if you have a solid foundation to start with then it may be less likely.
Agencymotorsports
lol i found this and wanted to share with you all...Screech from "saved by the bell" is loosing his house....
Black on Gold
gr8bryt wrote: ClubSx, what are your long term goals for this project? .
We'll i want something i can work with. Prolly once i have it boosted keep getting more and more aftermarket, stronger parts. I'd like this project (atleast by me being out of college) to have well over 300whp.
staticx1134 wrote:lol i found this and wanted to share with you all...Screech from "saved by the bell" is loosing his house....
Are you kidding me? I used to watch the hell out of that show. Funny, i watched this show at 7am when i got back from work
kouki munster
Car: 97 base 240
Count down to turning 21: 7hr 32min
Black on Gold
6 hr 35 min...
kouki munster
Car: 97 base 240
6hr
kouki munster
Car: 97 base 240
4hr 29min
Black on Gold
Haha. Thats awsome. I cant wait until im 21. I plan on being plastered before it even turn 12.
kouki munster
Car: 97 base 240
I was planning on hitting up my brother for a beer tonight while he was at work, then heading to a friends house and consuming larger amounts of alcohol.
oh and, 3hr 19min left
Black on Gold
I guess im going to see FNF3 at 10 10 by myself. Oh well. I need some time alone. Have fun man and stay safe
kouki munster
Car: 97 base 240
I wouldn't mind seeing it, I just don't want to pay to see it.
T minus 2hr 38min remaining
maxima278
happy 21st, man!
gr8bryt
HAPPY 21st BIRTHDAY!!
That's really great for you man, I remeber having to throw my own 21st b-day. It turned out to be a decent affair, even though I catered it. Just don't go overboard with the alcohol otherwise you might end up looking like this LOL. Dude I hope you have a blast, just watch out for da
gr8bryt
I think I'll buy myself a car to celebrate your birthday! I'm going down to Macon tomorrow to p/u my pig you guys; I'm really excited about everything, what a joyous occassion for everyone! )
gr8bryt
ClubSX wrote:We'll i want something i can work with. Prolly once i have it boosted keep getting more and more aftermarket, stronger parts. I'd like this project (atleast by me being out of college) to have well over 300whp.
As I always say, do your research. Don't just slap a bin of parts together and expect your motor to last. Inquire to companies like Top Hat to try to get some more info about how to make your motor more reliable. Sure all of us Niconauts are here to help, but you'll get your best source of info from the experts that do it all the time. Devise a strategy of how to tailor their approaches, as compared to the size of your budget. 300 rwhp is not an unrealistic request. That's just my $.02.
Black on Gold
Yea, i might have to email some SR and KA-T guys and give them my whole story. Im pretty sure it'll be SR. The thing that gets me is i still have to do a 5speed swap = /
kouki munster
Car: 97 base 240
Thanks guys, and you don't have to worry about me going overboard, I had a bad experiance with cheap vodka and a fat chick, (don't ask) so I no longer drink to the point that I don't know whats going on.
I also got that beer from my brother. (free beer rocks!!!)
Congrats on finaly getting your car gr8bryt.
The Duke
Car: 1989 nissan 240sx fastback
Here are some pics of my new sr. It's pretty nice.
The Duke
more
The Duke
here is the receipt. The clip was $2800. It came from a 180.
scs13
Car: 93 s13 coupe
i still hate you. when are you comin back here? the secret lives show is in asheville tonight. where are you at?
The Duke
another
The Duke
I'm at home right now. I'm down with going to the show. When is it and what venue?
Return to “Southeast Region”
