My VH45DE S13 swap thread
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
mtmetzger
Car: 1993 240SX coupe
Dammitboy wrote:Detailed pics would be great, need to make one of these also.
Here's a link to his post about that.
zach-s-build-thread-t470446-400.html#p5842605
mtmetzger
Oh, and if anyone's wondering why my progress has stopped, it's because I'm waiting on $6 worth of bolts for my updated timing chain guides. LOL.
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Been there. Done that. Haha. I'm looking forward to seeing your project move forward. I'm looking forward to seeing my project move forward, haha.
speedeast
Which wire did you connect to the fuel pump relay? The Pink/Black is one and either Green/Orange or Pink/Blue?
mtmetzger
Pink/black on VH harness goes to Black/Pink on S13 plug behind headlight. Those other 2 in the VH harness are for fuel pump control unit, which the S13 doesn't have, so I didn't use them.
speedeast
It operated properly with both of the other wires disconnected?
mtmetzger
Yes, of course you've seen how long mine ran for so I didn't get to test it out cruising, etc. From what I could gather, the control unit has a resistor in it like an RX-7. It will drop the voltage down to 8-10 volts on idle and cruising to prolong the life of the pump. This way the computer toggles the relay as necessary to send a full 12 to the pump. I'm sure you could always wire up the control unit if you want it to function like it's supposed to, but I wouldn't worry with it. Those boxes are the first thing to go when I have a turbo RX-7 LOL.
speedeast
I understand all of that. I just wanted to make sure I was good to go before I start sealing all of this stuff up. I really appreciate the help; it's been very useful.
Thanks to you tmorgan as well for the illustration. I printed it out and jotted notes on it.
mtmetzger
No problem at all.. I would rather share a little extra info that I have just in case ;)
speedeast
I do the same thing.
speedeast
How did you wire in your ignition coil relay?
mtmetzger
Just put another relay under the dash.
30 - Brown / Yellow in white connector (power to coils)
85 - Grey / Red wire in White connector (to pin 16 on ECU) (-) trigger from ECU
86 + 87 - Ignition power from key switch (or in my case switched power relay under dash)
speedeast
mtmetzger wrote:Just put another relay under the dash.
Do you know which fuse you used? I understand the logic behind a relay and I think I have a pretty strong grasp on how this all needs to be set up, BUT I'm the kind of person that needs to make sure; I prefer to make sure it's right the first time around.
I am using a spare Nissan relay that I have, identical to the fuel pump relay. I thought I knew how it should hook up according to the logistics of a relay, but the way the ignition coil was wired in the Q45 doesn't necessarily follow that same logic.
It's setup:
3 o----o-/ o----o 5
1 o-----mm-----o 2
__3|__5|__
2|______1|
I'm assuming the power source (which is also the power source for ignition and fuel pump relays in the Q45; B/W wire) is a 30amp constant source (illegible in my diagram) and connects to the #5 pin. The destination of the current (coils; Br/Y wire) should be connected to the #3 pin. The #1 pin in the Q45 is a 30amp source when the ignition is ACC/ON/ST (W/B wire). The remaining #2 pin is connected to the ECU and the ECCS Relay (Gy/R wire).
First off, is this accurate? Should it's connection in the S13 reflect exactly this? You mentioned that the 86 & 87 be power from the ignition switch, but I don't understand how that works compared to the way the relay is set-up in the Q45.
I guess I need to better understand the correlation between the #1 and #2 spots in the relay.
mtmetzger
speedeast wrote:I'm assuming the power source (which is also the power source for ignition and fuel pump relays in the Q45; B/W wire) is a 30amp constant source (illegible in my diagram) and connects to the #5 pin. The destination of the current (coils; Br/Y wire) should be connected to the #3 pin. The #1 pin in the Q45 is a 30amp source when the ignition is ACC/ON/ST (W/B wire). The remaining #2 pin is connected to the ECU and the ECCS Relay (Gy/R wire).
This is exactly right except on my diagram the B/W never really says where it goes... Just says to fuse block, but it's the same B/W wire that powers the fuel pump relay on the Q. I don't see the need to run a constant power wire to the relay at all, that's why I jumpered my coil side of the relay to the feed side.. Both will be powered when ignition is on anyway and only when the ignition is on. Plus I ran some stout wire from my switched power circuit to it so no need to worry about them drawing too much current. (Like I said, I put mine under the dash) Since you are doing wiring in the fuse box, and I'm not sure how much current the ignition coils draw, I would go ahead and run a wire on out to the battery with a 30A fuse on it and connect that one to the relay at position 4. Of course you could hide the fuse in a blank slot in the fuse box.
Nissan to normal SPDT relay
1 - 85
2 - 86
3 - 30
4 - 87
When #1 and #2 both have power and ground, #3 and #4 will make contact.
speedeast
I will assume that by 4 you mean 5, haha. That would pretty much confirm all I needed to know, thanks. I just did a little more homework on the wiring diagrams from the two cars and was able to deduce how I will be able to make this all happen and function properly. Again, thanks for all of the help. I had 15 wires total converting over, 6 of which I labeled as needing a power source. I read about someone using the A/C relay as the Ignition Coil relay. I was trying to configure this, but I would prefer not mess around with a 6-pin relay, when one of the spare 4's will do the correct job.
mtmetzger
Yup, that was my bad...
speedeast
I have the ignition coil wired up to two ignition sources now; apparently I had overlooked in the wiring diagram where it called for one source at ACC/ON/ST and one source at ON/ST. I am wiring them both to a ON/ST source. I created a "jumper" that connects to the ECCS harness inside and to the ERH in the front right corner. Getting close, man. How's it coming with you?
mtmetzger
Cool... I don't see why it would need ACC power anyway.
I'm still playing the waiting game... Somehow my $6 bolts became $19.87 shipped... I figured they might have expedited them for that price, but I guess not.
tmorgan4
Car: 2000 Nissan Pathfinder
Your wiring sounds a lot more complicated than mine! I don't think I touched a single relay under the hood. Everything I needed was already there and wired for the factory VG. Just cut and spliced wires under the dash and it ran great.
speedeast
I can imagine there being a big difference between the VG and the KA.
mtmetzger
Small update from the other day... I went to put in the new timing stuff and found out that my updated guides required longer bolts. That put me back another week while I waited for $6 worth of bolts to get here.
old style bolts / new style
Yay oil pump chain!
speedeast
Awesome. I hate waiting.
mtmetzger
Got the brake lines, etc back in the engine bay and dropped the engine back in. I hope to get some time this week to put everything else back on and fire it up!
speedeast
I like the clean white! Looking forward to your starting up. I finally got mine started; just makes all of the work and extra detail totally worth it!
67 411
Car: 1967 datsun 411 sss wagon 1975 datsun 620 king cab 4x4 and a 1971 521
looking good man cant wait to see it all done
mtmetzger
Lower intake manifolds back on:
Stupid engine doesn't use valve cover gaskets.. Took about an hour to remove the old RTV from them:
That's on:
Both on:
Brake booster, brake lines, plugs, coils, covers and fuel installed:
speedeast
Lookin good!
DRFTBLD
Car: 89 S13 VH45DETT
05 Ford F-150 Drift Support
91 S13 Tester
08 Ford Focus
Looks nice! Good build
mtmetzger
A little Sunday evening project... I had to add a small spacer to the front wheels so they would clear the Z32 calipers which left me with about 4-5 threads holding the wheels on. I figured this would be cheap insurance.
Fronts are for an Evo, rears are for a GM. 12X1.5 thread so my old RX7 lug nuts will work with them. :)
Used an old lug nut and a bunch of washers to pull them through the hub.
Plenty of thread holding now! :)
Thought this was a cool picture.
nevertheless
Car: 1993 240sx hatch
1995 Nissan D21
I like where this is going.
Return to “VH45DE / VK45DE / VK56DE Forum”
