1 - After putting the engine at TDC, I realized that my cam timing was off a couple teeth on the exhaust side of the left head... Didn't even check the right. Those lobes are supposed to be pointing right at the exhaust port and the notch in the cam is there so you can remove the head bolts, so it's supposed to be parallel.
2 - More broken chain guides
(This was on top of the oil pan baffle)
3 - What's missing here? The oil pump chain! WTF?!?!?!
4 - The oil pump pulley was free spinning on the crank shaft. There's a key way in it, but no key or place in the crank for a key. I guess it slides into the front chain pulley keyway, but it's MIA.
5 - This is really cute. I went fishing with a magnet in the oil pan to see if I could recover the oil pump chain and found this..
...part of it anyway.
So here are my options:
A- pull it back out, remove the oil pan to retrieve whatever is in there and hope the rest of the engine is good
B - Scrap this engine and put a KA in the b****
C - Pull it back out, break it down for inspection, hone, new rings, bearings, valve job gaskets, etc ($$$$$$$$)
I'm thinking option A for now.
