Zach's S13 Build Thread!! LOTS OF PICS! VH45 SWAP!
HeadAblaze
Car: Now: 1971 Datsun 510 w/ ka24e
Sold: Red 1990 240sx hatch
speedeast wrote:^Thanks!
Anybody not too far wanna help me find a s13 sending unit? I need one by the end of the week.
Ha, probably dumb quesion, but I am new to cars (used to be a bike person) butwhat is the sending unit? I have a ka24de motor that's disassembled so I might have one.
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
It's the cradle that holds the fuel pump in the fuel tank. I found one though. Thanks anyways.
speedeast
Update!
A lot has been accomplished since the last update, and a lot will be accomplished before the next. The goal to crank her up tomorrow still stands. Here goes...
We'll start with the fan controller. I acquired one from the local speed shop, AA Speed & Custom. They have a real nice outfit and the prices are decent; although, there in stock merchandise is geared toward American muscle cars. Anyway, I got the Flex-A-Lite fan controller, and it is temperature adjustable. It's the kind that you push through the fins at the radiator inlet.
Next up are the heater hoses. I never had the one heater line that reaches all the way to the thermostat housing, so when I finally got one, I had already installed a bunch of s*** around it. So, taking that into consideration and the fact that the bend at the firewall would be brutal, I went ahead and cut the pipe down to where it was a little under two inches long and installed it like that. That way the heater hose has a longer distance to distribute the 90 degree curve to the firewall and it works out much better. When it finally gets to the firewall, it still has to bend brutally to hook to the heater core. I went digging around at the parts store until I found an elbow that would help me out. The elbow worked great, the only problem is that the parts store only had one. So, I have to find another one today sometime so I can finish the heater lines. On the other heater line, I used one of those stainless coils that are supposed to keep it from bending. It seems to be working real good right now, though.
My friend, Santi, came by to help me out for a few hours. In that time, he installed my fuel hard lines for me and a few other things. We used the rubber insulated clasps to hold them in place. The lines are 3/8" aluminum feed and return. Then I cut up some 5/16" rubber fuel line and began installing and decorating with band clamps. I also created a custom fuel filter bracket because the oem I had was covered in yellow paint and bad memories, so I just said f*** it.
Next up, the electrical stuff that I got accomplished; although, there are still plenty of hours worth of it left to go. I took lots of notes: 1, I like to be organized so I can minimize mistakes; 2, I plan on doing a complete write-up on the elctrical changes required to VH --> S13 swap. I turned one of my pick tools into my new "connector removal tool." I can now pull all of the wires effortlessly out of the connectors for whatever reason I want I suppose. I removed the interior EFI connector from the KA... that was just a few seconds before I realized the VH connector is identical, oh well. I also pulled the 2 connectors off of the KA harness that connected to the "Engine Room Harness" with as much wire as I could manage. i plan to use these to create a bridge from the VH harness to the KA "Engine Room Harness." I finished sprucing up the injector harness. I also made note of the part number for the coil pack harness, just in case. I noticed that the letter/numbers were wearing away. I also installed the starter. The power wire from the starter will connect to the terminal shown in the last picture below.
There will be more!
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Good progress Zach. Just remember slow is smooth and smooth is fast.
speedeast
Words to live by.
39c240sx
Car: 1995 240sx se.
This is one interesting build, Read all 11 pages and was just fascinated with all your work. Keep it up dude :dblthumb:
Btw I just painted my car the Porsche Midnight Blue Metallic and it came out beautifully.. Love the color and didnt regret it at all. Just incase you interested the code is 39c. I will post up a pic in a second.
This is the color i went with on my s14
This is another color i was considering, I think it would look beautifull on my car which is an s14.
PyR0NiAk
39c240sx, thread jack much?
39c240sx
Car: 1995 240sx se.
PyR0NiAk wrote:39c240sx, thread jack much?
how is it thread jack? he was debating a dark color to paint his car. I showed up 2 colors...
speedeast wrote:I suppose I need to start looking for a place to work on her at.
I am questioning the paint options. I haven't yet 100% decided on a color. I was stuck on Gloss Black for a long time, but the closer I get to painting it, the more I am still up in the air.
What do you guys think? Interior will remain black regardless. I don't want anything too flashy. I like darker colors. The two tone: color bottom, black top is also on the shelf...
Please share.
He is asking us what do we think.. My post up above is what i think would look good on a 240sx..
39c240sx wrote:This is one interesting build, Read all 11 pages and was just fascinated with all your work. Keep it up dude :dblthumb:
He was interested in the Lapis Blue Metallic from the porsche so i figured he would like the Midnight Blue Metallic. So i posted the Paint Code for it..Again i thought i was helping, If you think its thread jacking then im sorry.
speedeast
It's cool. I like both of the colors, but I've already made a decision. I'm going with the Mazda Lapis Blue Metallic.
As for forward progress on the car and getting it to start... Today was a fail of epic proportions. I was hung over; little things kept frustrating me all day; and some important tools were misplaced. All was expected, but I was hoping to get further.
All electrical has been resolved; write-up coming soon. Vacuum lines and coolants lines all resolved as well. Power steering pump is almost fully mocked up. Fuel tank I purchased was cleaned, and will soon be installed. I have acquired the sending unit, and it is VERY clean! I already have 4 gallons of unleaded 93 ready to go in. I knocked a bunch of other tasks off my to-do list, but didn't quite reach the ultimate goal. There are still a couple of issues. Brake booster clearance worries me. I think there is 2-3mm clearance between the valve cover and the brake booster. Fortunately, I don't need brakes to hear her run. In the morning, I have to make a run to the parts store and get a couple things. I should have another nice update at some point tomorrow. Thanks for all the support guys.
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
Just read your whole build, excellent work man! Wish I had half the fabrication ability you do. Can't wait to see it when its done.
btw thanks for sharing the info about the chassis saver paint earlier in the thread, just picked up a quart today. Gonna do my subframe/rear suspension components and hopefully the engine bay this weekend.
speedeast
Just a heads up for you. In my engine bay, the chassis saver served as a primer. I would also recommend chassis saver directly on the metal. If you want to paint it after that you can.
PyR0NiAk
39c240sx, I called it a threadjack because of the fact you continually talked about your S14. Saying things such as "I think it would look beautiful on my car, which is an S14." Either way, it's over and done with.
Zach, if I ever get a free weekend after I get back to NC, I still plan on trying to come up and help you. And what's wrong with 2-3mms? You put a V8 in a car designed for a 4 cylinder. Things are suppose to be tight. ;)
39c240sx
Car: 1995 240sx se.
speedeast wrote:It's cool. I like both of the colors, but I've already made a decision. I'm going with the Mazda Lapis Blue Metallic.
That blue does look good as heck... Btw.
PyR0NiAk wrote:39c240sx, I called it a threadjack because of the fact you continually talked about your S14. Saying things such as "I think it would look beautiful on my car, which is an S14." Either way, it's over and done with.
Im just giving him an idea on how the color looks on a s14, Not every color looks good on a specific car.
SX APPEAL
95 Maxima SE 5MT
speedeast wrote:Just a heads up for you. In my engine bay, the chassis saver served as a primer. I would also recommend chassis saver directly on the metal. If you want to paint it after that you can.
no worries man, I'm not really making it pretty, just liked the idea of a rust and chemical proof coating that I could brush on
speedeast
SX APPEAL wrote:no worries man, I'm not really making it pretty, just liked the idea of a rust and chemical proof coating that I could brush on
I understand, but when chassis saver or anything like it is exposed to UV light (sunlight) it gradually fades to a flat dark dark gray. It will always retain it's rust preventative value, but it fades.
39c240sx wrote:That blue does look good as heck... Btw.
That's the color that's on my Mazda 6 now, love it!
PyR0NiAk wrote:Zach, if I ever get a free weekend after I get back to NC, I still plan on trying to come up and help you. And what's wrong with 2-3mms? You put a V8 in a car designed for a 4 cylinder. Things are suppose to be tight. ;)
Check, and check. Well, the 2-3mm concerned me because though my mounts are very stiff, they are not solid. I don't want the engine movement affecting my brake system.
Dammitboy
Car: 92' Nissan 240
speedeast wrote:All electrical has been resolved; write-up coming soon.
Definately looking forward to this. This is the only part of the swap I'm unsure of.
Really enjoying your build, It's given me alot of good ideas.
speedeast
On some of my more "creative" projects... consult with me before you duplicate just in case new information has arisen or I developed a better way, or found issues. Thanks for all of the praise and support; it helps keep me going. I mentioned that the wiring was resolved, and in patching things together I came up with some more questions that I've been looking into; therefore, the wiring isn't completely done, but a write-up is definitely coming. I plan to not only show what I did, but why I did it that way so everybody understands where I'm coming from.
Dammitboy
Car: 92' Nissan 240
Sounds good. I have amassed everything I need to do this, just waiting to start this in January when my S13 will be officially retired. In the meantime, I have the engine apart for freshening up & powder coating.
Can't wait till' you get her started!
speedeast
They officially retire them in January? I kind of figured they retired them on the anniversary of the manufacture date. Oh well. Mine is officially 21 years old, but that's still not old enough here in Prince William County, Virginia. Joy!
I hope to get her started real soon. I had a friend in town to help this weekend, but things weren't right so we never got it going. I have since then been taking my time a bit, but I've been learning a lot about what I'm doing rather than just doing what others tell me to do. This will make for quite a write-up.
speedeast
Tonight I will catch this thread up to speed with what's been going on. Not yet running, but made a lot of progress.
speedeast
I decided not to update last night for the sake of exposure and pure amount of time uploading 100 more pictures. That's right, 100 more pictures. Through the next couple hours I will be organizing my progress as well as a full write-up on the 91 VH --> 90 KA wiring the way that I did it.
For the sake of picture count, there will be a separate thread for VH -> KA wiring, which I will link from this thread.
speedeast
Update time!
I am working down and checking things off of my list of tasks to accomplish in order to start up the car. One of these tasks was to replace the o-rings sealing up the oil filter adapter. This task was a lot more involved than it may seem. I supported the engine in place, removed the mount on the driver's side, removed the bolts from the adapter, replaced the 0-rings, replaced the adapter, replaced the adapter bolts, replaced the mounts, etc. The worst part of the project was that one of the mount bolts required a hex wrench, but for some reason my metric set was missing. 45 minutes and $7 later I had a replacement hex and one hell of a bad attitude, haha.
Next up... I needed to add a "T" into the heater hose line in order have a supply and return for the throttle body coolant. I cut the "T" piece out of the old heater hard pipe and inserted it midway down the heater hose where it would be convenient. Then I finished off the heater lines with coolant elbows and several hose clamps.
Then, just because it was easy, I installed the horns.
I mocked up the engine room harness in place to see if there were any modifications to be made. At the very last connector, the one to the ASCD, the rubber grommet needed to be modified to accommodate the power wire from the rear-mounted battery. Although the ASCD won't be utilized, I hooked it all up the way it was anyhow just to make sure all of the circuits were complete.
I didn't have the OEM fuse box mount and didn't want to mount it exactly in the OEM position anyways; therefore, I bent, cut, and drilled up another piece of aluminum to act as a mount. It's very simple, but works very well. After everything is done and I start doing things to improve the aesthetics, I will probably modify this mount or add another to better support the fuse box, but I am thoroughly satisfied for now.
I taped/loomed/sealed up the engine room harness and reassembled the relay box.
Here's a shot of my mid-wiring mess:
Threw the taillights in... gotta make sure they work, right?
I had to replace the sub-crank angle sensor connector on the harness side because it was broken and the clasp was broken off. I pulled the connector from a donor car at the junkyard before it got crushed... phew! good timing.
Another mid-wiring mess shot:
The good thing about that mess is that it functions! All body electrical systems are a go!
I got the fuel tank cleaned out, got a replacement sending unit (which is mighty clean!), and installed my Walbro 255. I do expect to need to replace the fuel pump "sock" after the first few fuel ups, so I sourced a place to buy the sock without the pump. It's the entire install kit, but for only $18 you can't go wrong. I also replaced all of the fuel tank hardware with stainless hardware!
http://www.frsport.com/Walbro-High-Flow ... _7723.html
Just to break up my updates, I will break this post here.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
looking awesome man can't wait to see it fire up!!!
speedeast
I wanted that to be today, but I got caught up with work most of the day. I won't actually be getting into the garage until 8 or so.
I have more update for now though...
speedeast
In my wiring challenge, something popped right off the transmission. It's enough to piss me off, but not enough to keep me from starting it. One connector on the transmission popped off, wire and all. The only thing left behind is the sensor. I haven't taken the time to inspect that yet but it's either the reverse light switch or the 5th position switch - one of which doesn't concern me.
I finished wiring up my fans. I'll just let the pictures do the talking on this one.
I installed the ignition coil harnesses and the valve cover inserts. I replaced all of the hardware on the inserts with some shiny, new stainless hardware. :P In the first picture you can see that I sanded the harness grounds to make sure they would make good contact; they're important.
Belts in place, and as you can see, the power steering pump is installed down near where it would have been on the Q. 47.8" belt length on that one; OEM calls for 50.6 inches. The alternator belt is 34" for my application, I believe.
More wiring mess with washer fluid reservoir... The harness that goes up and along the left side is the jumper I created to convert the VH to the KA body. There will be a write-up for that soon when I get all of my information organized. The loomed harness that goes down next to the frame rail carries wiring to the starter and transmission; the harness tied to that one goes to the alternator. They are both actually part of the same compound harness. I had to extend the transmission wiring, and all that is also going to be covered in the write-up.
I will be in NY for the weekend... if it doesn't start tonight, then it will be early next week. I can't promise though because I've had a lot of small things pushing it back further and further.
speedeast
And for my biggest update:
how-to-1991-vh45de-1990-s13-wiring-t513843.html
That's the wiring, folks. Enjoy!
speedeast
Anybody know where I can find some good 3.5" intake tubing?
speedeast
Anybody?
S13AL
Car: 1991 240sx hatch with blacktop s13 sr20det, HKS Hipermax III suspension, HKS Sport exhaust, Blitz downpipe, S15 Sylvia HLSD, 300zx/J30 5 lug and brakes, and mesh wheels
Good progress. Do you mind me asking what the car is going to be used for?
speedeast
I don't mind - mostly track.
