kevwa »
https://forums.nicoclub.com/kevwa-u75921.html
Sun Aug 02, 2009 2:36 pm
Here the latest update - my progress is not happening as fast as I would like but thats the way custom work goes i guess - and im only working on it on weekends since it is at my parents house. anyway I got the motor mounts installed - They went alot smoother then in the other truck since i had a better idea of what i was doing. I wasnt satisfied with the mounts I had originally made since they were just pieced together - especially the passenger side mount - this time around I made them more symmetrical on both sides - I think it makes the swap look that much cleaner and presentable - they are not 100% done b/c I still need to add a few gussets to them for strength but I was more concerned with getting the final fitment of the motor so I could figure out how everything else will fit, then I will go back through everything and button it up.
these pictures dont show it but with the body drop my factory brake booster is too close to the manifold which does not leave room for the downpipe. I took the booster off and the downpipe dose clear the fire wall. The stock booster is almost 11" in diameter so I found a 7" diameter booster which appears will work with the downpipe - I will find out as soon as I order it.
Once I had the motor mounted I needed to get the floor welded back together. however, it was such a mess that i decided I would get rid of the factory floor and make my own. It has taken me longer than I wanted but I have the frame just about complete for the new floor. I still need to cut some more of the back section of the cab out so the drive shaft will fit. here is how she stands as of this afternoon...
