float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun Mar 17, 2013 9:36 pm
I got it from Themadscientist. I had been after one for years, but they're VERY hard to get a hold of. I had told him if he ever decided to sell, I'd buy, and when his motor popped, I picked it up.
It's not really a twin scroll manifold so much as a paired manifold. A paired manifold connects exhaust ports together that don't interfere with each other, thereby reducing the risk of exhaust back flow into the cylinders. On a typical I4 cylinders 1&4 and 2&3 are paired. This can be seen on most long length headers. In a turbocharged vehicle, the use a twin scroll turbine housing, mated to a paired runner manifold can further help to reduce any chance of reversion. The pro's of a setup like this are that for a given A/R, the turbo will usually spool faster, have faster response, but may loose some top end power due to the smaller ports for a given A/R in a twin scroll manifold (the area is the same, but divided in half). What is more typically done is that a larger A/R housing is fitted. Depending on how much larger, the turbo may still spool faster and have better top end power. The con to all of this is cost and complexity.
This whole concept is the reason I push people to keep their stock manifolds. The stock manifold is a paired design. One of the first things I did to my CA was to put a tubular manifold on it and it KILLED the bottom end power and responsiveness of the motor. I did gain some top end power, but overall, I felt like the car was slower.
