Engine: Ca18det
Mods:
Fmic
hks ssqv
t25g
Trans Stock
centerforce dual friction stage 2
nismo short shifter
Exhaust
s13 3 inch exhaust modded to fit the s12
not sure the name of the muffler
suspension
tokico adjustables
canuck springs
Wheels
Sportmax xxr 15x8 0 offset
Extras
nismo buckets
hids
new water pump
turbo timer
factory service manual for the 87 s12
factory wiring schematic for the 87 s12
t28
t25g
gauge pods
egt gauge
boost gauge
Upolstery to reupolster the car.
That's all I can remember right now I'll update as I find more
Now on with the pics exterior only because it was to windy to do the interior lol
Yeah the hot pipe is a custom job by me lol the hot pipe he had didn't fit after I swapped turbos it was off by three inches so I got some rad pipe and used the coupler to make it fit lol some mcgyver s*** just needed it to run so while tow on oacassion I could start the motor to charge the battery so my lights and hazards don't go dead lol.
Well about a month ago my window some jackass decided to break my pass window for what reason I don't know but i do know who did it...lol and they will get theirs in due time well iwent to the jy and bought a new window which happened to have the same purple tin t the rest of the car has lol which was perfect lol then My girl got bored and decided to clean my rims and now they are blinging lol
Ok Iggy, My girl and myself pulled apart the motor last and found very minimal damage to the motor first the head gasket was blown and second the #4 piston had a very slight hole around the edge near th cyl wall so from an assement last night I need a head gasket and a piston luckily I bought rods and pistons from the det for my single cam project so I have a spare set lol while I'm in there I'm gonna rering all 4 and check the bearings and make sure they are within spec then hopefully I can this bad boy up and running by the end of the month.
alright got some pics of the damage turnsout not only was the piston burned but we found broken ring lands actually I should say destroyed ring lands lol on with the pics...
no.4
compared to no.1
ringland comparison the broken one is no.4
Sorry the flash f*** it up but without it you cant see it lol anyway I have spare rods and pistons that were for my single cam project so I will be replacing the number 4 piston also will be replacing the rings on all of them and also the bearings they weren't to bad but I figure why not since they are out....oh and btw the det is way easier to work on than the single cam lol. But don't get it twisted I still love the single cam....
sorry if some of it doesn't make sense I kinda just copied an pasted it from my build thread on cs12
